Datasheet Songle Relay SRU-05VDC-SD-C — Даташит
| Производитель | Songle Relay |
| Серия | SRU (22F) |
| Модель | SRU-05VDC-SD-C |
Реле для бытовых электроприборов
Datasheet SRU
PDF, 3.9 Мб, Файл закачен: 22 фев 2018, Страниц: 2
Subminature High Power Relay 7A/10A/15A
Купить SRU-05VDC на РадиоЛоцман.Цены — от 32 до 173 ₽ 1071783211 | |||
| SRU-05VDC-SL-C | 32 ₽ | ||
| Реле 05V 10A (SRU-05VDC-SL-C) | 173 ₽ | ||
| SRU-05VDC-SL-C Songle Relay | по запросу | ||
| Размеры | 29.0×24.5×15.0 | 32.0×27.4×20.0 мм |
| Номинальное рабочее напряжение | 5 В |
Серия: SRU (22F) (96)
- SRU-05VDC-FD-A SRU-05VDC-FD-B SRU-05VDC-FD-C SRU-05VDC-FL-A SRU-05VDC-FL-B SRU-05VDC-FL-C SRU-05VDC-SD-A SRU-05VDC-SD-B SRU-05VDC-SD-C SRU-05VDC-SL-A SRU-05VDC-SL-B SRU-05VDC-SL-C SRU-06VDC-FD-A SRU-06VDC-FD-B SRU-06VDC-FD-C SRU-06VDC-FL-A SRU-06VDC-FL-B SRU-06VDC-FL-C SRU-06VDC-SD-A SRU-06VDC-SD-B SRU-06VDC-SD-C SRU-06VDC-SL-A SRU-06VDC-SL-B SRU-06VDC-SL-C SRU-09VDC-FD-A SRU-09VDC-FD-B SRU-09VDC-FD-C SRU-09VDC-FL-A SRU-09VDC-FL-B SRU-09VDC-FL-C SRU-09VDC-SD-A SRU-09VDC-SD-B SRU-09VDC-SD-C SRU-09VDC-SL-A SRU-09VDC-SL-B SRU-09VDC-SL-C SRU-12VDC-FD-A SRU-12VDC-FD-B SRU-12VDC-FD-C SRU-12VDC-FL-A SRU-12VDC-FL-B SRU-12VDC-FL-C SRU-12VDC-SD-A SRU-12VDC-SD-B SRU-12VDC-SD-C SRU-12VDC-SL-A SRU-12VDC-SL-B SRU-12VDC-SL-C SRU-18VDC-FD-A SRU-18VDC-FD-B SRU-18VDC-FD-C SRU-18VDC-FL-A SRU-18VDC-FL-B SRU-18VDC-FL-C SRU-18VDC-SD-A SRU-18VDC-SD-B SRU-18VDC-SD-C SRU-18VDC-SL-A SRU-18VDC-SL-B SRU-18VDC-SL-C SRU-24VDC-FD-A SRU-24VDC-FD-B SRU-24VDC-FD-C SRU-24VDC-FL-A SRU-24VDC-FL-B SRU-24VDC-FL-C SRU-24VDC-SD-A SRU-24VDC-SD-B SRU-24VDC-SD-C SRU-24VDC-SL-A SRU-24VDC-SL-B SRU-24VDC-SL-C SRU-36VDC-FD-A SRU-36VDC-FD-B SRU-36VDC-FD-C SRU-36VDC-FL-A SRU-36VDC-FL-B SRU-36VDC-FL-C SRU-36VDC-SD-A SRU-36VDC-SD-B SRU-36VDC-SD-C SRU-36VDC-SL-A SRU-36VDC-SL-B SRU-36VDC-SL-C SRU-48VDC-FD-A SRU-48VDC-FD-B SRU-48VDC-FD-C SRU-48VDC-FL-A SRU-48VDC-FL-B SRU-48VDC-FL-C SRU-48VDC-SD-A SRU-48VDC-SD-B SRU-48VDC-SD-C SRU-48VDC-SL-A SRU-48VDC-SL-B SRU-48VDC-SL-C
- Household appliance relay
SRU05VDCSDC, SRU 05VDC SD C
