Datasheet Songle Relay SMI-24VDC-FL-A — Даташит
Производитель | Songle Relay |
Серия | SMI (14F) |
Модель | SMI-24VDC-FL-A |
Реле для бытовых электроприборов
Datasheet SMI-1P
PDF, 3.6 Мб, Файл закачен: 22 фев 2018, Страниц: 2
Subminature High Power Relay 10A
![]() 9 предложений от 5 поставщиков Реле электромагнитное 24 В DPDT 2 формы C, 8 DIP, 13x29,2мм | |||
SMI-24VDC-SL-2C Реле | 136 ₽ | ||
SMI-24VDC-SL-2C Songle Relay | от 140 ₽ | ||
SMI-24VDC-SL-2C | по запросу | ||
SMI-24VDC-SL-2C Songle Relay | по запросу |
Размеры | 28.9×12.6×20.6 мм |
Номинальное рабочее напряжение | 24 В |
Серия: SMI (14F) (96)
- SMI-05VDC-FD-A SMI-05VDC-FD-B SMI-05VDC-FD-C SMI-05VDC-FL-A SMI-05VDC-FL-B SMI-05VDC-FL-C SMI-05VDC-SD-A SMI-05VDC-SD-B SMI-05VDC-SD-C SMI-05VDC-SL-A SMI-05VDC-SL-B SMI-05VDC-SL-C SMI-06VDC-FD-A SMI-06VDC-FD-B SMI-06VDC-FD-C SMI-06VDC-FL-A SMI-06VDC-FL-B SMI-06VDC-FL-C SMI-06VDC-SD-A SMI-06VDC-SD-B SMI-06VDC-SD-C SMI-06VDC-SL-A SMI-06VDC-SL-B SMI-06VDC-SL-C SMI-09VDC-FD-A SMI-09VDC-FD-B SMI-09VDC-FD-C SMI-09VDC-FL-A SMI-09VDC-FL-B SMI-09VDC-FL-C SMI-09VDC-SD-A SMI-09VDC-SD-B SMI-09VDC-SD-C SMI-09VDC-SL-A SMI-09VDC-SL-B SMI-09VDC-SL-C SMI-12VDC-FD-A SMI-12VDC-FD-B SMI-12VDC-FD-C SMI-12VDC-FL-A SMI-12VDC-FL-B SMI-12VDC-FL-C SMI-12VDC-SD-A SMI-12VDC-SD-B SMI-12VDC-SD-C SMI-12VDC-SL-A SMI-12VDC-SL-B SMI-12VDC-SL-C SMI-18VDC-FD-A SMI-18VDC-FD-B SMI-18VDC-FD-C SMI-18VDC-FL-A SMI-18VDC-FL-B SMI-18VDC-FL-C SMI-18VDC-SD-A SMI-18VDC-SD-B SMI-18VDC-SD-C SMI-18VDC-SL-A SMI-18VDC-SL-B SMI-18VDC-SL-C SMI-24VDC-FD-A SMI-24VDC-FD-B SMI-24VDC-FD-C SMI-24VDC-FL-A SMI-24VDC-FL-B SMI-24VDC-FL-C SMI-24VDC-SD-A SMI-24VDC-SD-B SMI-24VDC-SD-C SMI-24VDC-SL-A SMI-24VDC-SL-B SMI-24VDC-SL-C SMI-36VDC-FD-A SMI-36VDC-FD-B SMI-36VDC-FD-C SMI-36VDC-FL-A SMI-36VDC-FL-B SMI-36VDC-FL-C SMI-36VDC-SD-A SMI-36VDC-SD-B SMI-36VDC-SD-C SMI-36VDC-SL-A SMI-36VDC-SL-B SMI-36VDC-SL-C SMI-48VDC-FD-A SMI-48VDC-FD-B SMI-48VDC-FD-C SMI-48VDC-FL-A SMI-48VDC-FL-B SMI-48VDC-FL-C SMI-48VDC-SD-A SMI-48VDC-SD-B SMI-48VDC-SD-C SMI-48VDC-SL-A SMI-48VDC-SL-B SMI-48VDC-SL-C
- Household appliance relay
SMI24VDCFLA, SMI 24VDC FL A
