Datasheet Songle Relay SMI-2P (14FD) — Даташит
ПроизводительSongle Relay
СерияSMI-2P (14FD)
Реле для бытовых электроприборов
Datasheet SMI-2P
PDF, 3.7 Мб, Файл закачен: 22 фев 2018, Страниц: 2
Subminature High Power Relay 5A
SMI-05VDC-FD-2ASMI-05VDC-FD-2BSMI-05VDC-FD-2CSMI-05VDC-FL-2ASMI-05VDC-FL-2BSMI-05VDC-FL-2CSMI-05VDC-SD-2ASMI-05VDC-SD-2BSMI-05VDC-SD-2CSMI-05VDC-SL-2ASMI-05VDC-SL-2BSMI-05VDC-SL-2CSMI-06VDC-FD-2ASMI-06VDC-FD-2BSMI-06VDC-FD-2CSMI-06VDC-FL-2ASMI-06VDC-FL-2BSMI-06VDC-FL-2CSMI-06VDC-SD-2ASMI-06VDC-SD-2BSMI-06VDC-SD-2CSMI-06VDC-SL-2ASMI-06VDC-SL-2BSMI-06VDC-SL-2CSMI-09VDC-FD-2ASMI-09VDC-FD-2BSMI-09VDC-FD-2CSMI-09VDC-FL-2ASMI-09VDC-FL-2BSMI-09VDC-FL-2CSMI-09VDC-SD-2ASMI-09VDC-SD-2BSMI-09VDC-SD-2CSMI-09VDC-SL-2ASMI-09VDC-SL-2BSMI-09VDC-SL-2CSMI-12VDC-FD-2ASMI-12VDC-FD-2BSMI-12VDC-FD-2CSMI-12VDC-FL-2ASMI-12VDC-FL-2BSMI-12VDC-FL-2CSMI-12VDC-SD-2ASMI-12VDC-SD-2BSMI-12VDC-SD-2CSMI-12VDC-SL-2ASMI-12VDC-SL-2BSMI-12VDC-SL-2CSMI-18VDC-FD-2ASMI-18VDC-FD-2BSMI-18VDC-FD-2CSMI-18VDC-FL-2ASMI-18VDC-FL-2BSMI-18VDC-FL-2CSMI-18VDC-SD-2ASMI-18VDC-SD-2BSMI-18VDC-SD-2CSMI-18VDC-SL-2ASMI-18VDC-SL-2BSMI-18VDC-SL-2CSMI-24VDC-FD-2ASMI-24VDC-FD-2BSMI-24VDC-FD-2CSMI-24VDC-FL-2ASMI-24VDC-FL-2BSMI-24VDC-FL-2CSMI-24VDC-SD-2ASMI-24VDC-SD-2BSMI-24VDC-SD-2CSMI-24VDC-SL-2ASMI-24VDC-SL-2BSMI-24VDC-SL-2CSMI-36VDC-FD-2ASMI-36VDC-FD-2BSMI-36VDC-FD-2CSMI-36VDC-FL-2ASMI-36VDC-FL-2BSMI-36VDC-FL-2CSMI-36VDC-SD-2ASMI-36VDC-SD-2BSMI-36VDC-SD-2CSMI-36VDC-SL-2ASMI-36VDC-SL-2BSMI-36VDC-SL-2CSMI-48VDC-FD-2ASMI-48VDC-FD-2BSMI-48VDC-FD-2CSMI-48VDC-FL-2ASMI-48VDC-FL-2BSMI-48VDC-FL-2CSMI-48VDC-SD-2ASMI-48VDC-SD-2BSMI-48VDC-SD-2CSMI-48VDC-SL-2ASMI-48VDC-SL-2BSMI-48VDC-SL-2C
N123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596
Размеры, мм28.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.6
Parameters / ModelsSMI-05VDC-FD-2A
SMI-05VDC-FD-2A
SMI-05VDC-FD-2B
SMI-05VDC-FD-2B
SMI-05VDC-FD-2C
SMI-05VDC-FD-2C
SMI-05VDC-FL-2A
SMI-05VDC-FL-2A
SMI-05VDC-FL-2B
SMI-05VDC-FL-2B
SMI-05VDC-FL-2C
SMI-05VDC-FL-2C
SMI-05VDC-SD-2A
SMI-05VDC-SD-2A
SMI-05VDC-SD-2B
SMI-05VDC-SD-2B
SMI-05VDC-SD-2C
SMI-05VDC-SD-2C
SMI-05VDC-SL-2A
SMI-05VDC-SL-2A
SMI-05VDC-SL-2B
SMI-05VDC-SL-2B
SMI-05VDC-SL-2C
SMI-05VDC-SL-2C
SMI-06VDC-FD-2A
SMI-06VDC-FD-2A
SMI-06VDC-FD-2B
SMI-06VDC-FD-2B
SMI-06VDC-FD-2C
SMI-06VDC-FD-2C
SMI-06VDC-FL-2A
SMI-06VDC-FL-2A
SMI-06VDC-FL-2B
SMI-06VDC-FL-2B
SMI-06VDC-FL-2C
SMI-06VDC-FL-2C
SMI-06VDC-SD-2A
SMI-06VDC-SD-2A
SMI-06VDC-SD-2B
SMI-06VDC-SD-2B
SMI-06VDC-SD-2C
SMI-06VDC-SD-2C
SMI-06VDC-SL-2A
SMI-06VDC-SL-2A
SMI-06VDC-SL-2B
SMI-06VDC-SL-2B
SMI-06VDC-SL-2C
SMI-06VDC-SL-2C
SMI-09VDC-FD-2A
SMI-09VDC-FD-2A
SMI-09VDC-FD-2B
SMI-09VDC-FD-2B
SMI-09VDC-FD-2C
SMI-09VDC-FD-2C
SMI-09VDC-FL-2A
SMI-09VDC-FL-2A
SMI-09VDC-FL-2B
SMI-09VDC-FL-2B
SMI-09VDC-FL-2C
SMI-09VDC-FL-2C
SMI-09VDC-SD-2A
SMI-09VDC-SD-2A
SMI-09VDC-SD-2B
SMI-09VDC-SD-2B
SMI-09VDC-SD-2C
SMI-09VDC-SD-2C
SMI-09VDC-SL-2A
SMI-09VDC-SL-2A
SMI-09VDC-SL-2B
SMI-09VDC-SL-2B
SMI-09VDC-SL-2C
SMI-09VDC-SL-2C
SMI-12VDC-FD-2A
SMI-12VDC-FD-2A
SMI-12VDC-FD-2B
SMI-12VDC-FD-2B
SMI-12VDC-FD-2C
SMI-12VDC-FD-2C
SMI-12VDC-FL-2A
SMI-12VDC-FL-2A
SMI-12VDC-FL-2B
SMI-12VDC-FL-2B
SMI-12VDC-FL-2C
SMI-12VDC-FL-2C
SMI-12VDC-SD-2A
SMI-12VDC-SD-2A
SMI-12VDC-SD-2B
SMI-12VDC-SD-2B
SMI-12VDC-SD-2C
SMI-12VDC-SD-2C
SMI-12VDC-SL-2A
SMI-12VDC-SL-2A
SMI-12VDC-SL-2B
SMI-12VDC-SL-2B
SMI-12VDC-SL-2C
SMI-12VDC-SL-2C
SMI-18VDC-FD-2A
SMI-18VDC-FD-2A
SMI-18VDC-FD-2B
SMI-18VDC-FD-2B
SMI-18VDC-FD-2C
SMI-18VDC-FD-2C
SMI-18VDC-FL-2A
SMI-18VDC-FL-2A
SMI-18VDC-FL-2B
SMI-18VDC-FL-2B
SMI-18VDC-FL-2C
SMI-18VDC-FL-2C
SMI-18VDC-SD-2A
SMI-18VDC-SD-2A
SMI-18VDC-SD-2B
SMI-18VDC-SD-2B
SMI-18VDC-SD-2C
SMI-18VDC-SD-2C
SMI-18VDC-SL-2A
SMI-18VDC-SL-2A
SMI-18VDC-SL-2B
SMI-18VDC-SL-2B
SMI-18VDC-SL-2C
SMI-18VDC-SL-2C
SMI-24VDC-FD-2A
SMI-24VDC-FD-2A
SMI-24VDC-FD-2B
SMI-24VDC-FD-2B
SMI-24VDC-FD-2C
SMI-24VDC-FD-2C
SMI-24VDC-FL-2A
SMI-24VDC-FL-2A
SMI-24VDC-FL-2B
SMI-24VDC-FL-2B
SMI-24VDC-FL-2C
SMI-24VDC-FL-2C
SMI-24VDC-SD-2A
SMI-24VDC-SD-2A
SMI-24VDC-SD-2B
SMI-24VDC-SD-2B
SMI-24VDC-SD-2C
SMI-24VDC-SD-2C
SMI-24VDC-SL-2A
SMI-24VDC-SL-2A
SMI-24VDC-SL-2B
SMI-24VDC-SL-2B
SMI-24VDC-SL-2C
SMI-24VDC-SL-2C
SMI-36VDC-FD-2A
SMI-36VDC-FD-2A
SMI-36VDC-FD-2B
SMI-36VDC-FD-2B
SMI-36VDC-FD-2C
SMI-36VDC-FD-2C
SMI-36VDC-FL-2A
SMI-36VDC-FL-2A
SMI-36VDC-FL-2B
SMI-36VDC-FL-2B
SMI-36VDC-FL-2C
SMI-36VDC-FL-2C
SMI-36VDC-SD-2A
SMI-36VDC-SD-2A
SMI-36VDC-SD-2B
SMI-36VDC-SD-2B
SMI-36VDC-SD-2C
SMI-36VDC-SD-2C
SMI-36VDC-SL-2A
SMI-36VDC-SL-2A
SMI-36VDC-SL-2B
SMI-36VDC-SL-2B
SMI-36VDC-SL-2C
SMI-36VDC-SL-2C
SMI-48VDC-FD-2A
SMI-48VDC-FD-2A
SMI-48VDC-FD-2B
SMI-48VDC-FD-2B
SMI-48VDC-FD-2C
SMI-48VDC-FD-2C
SMI-48VDC-FL-2A
SMI-48VDC-FL-2A
SMI-48VDC-FL-2B
SMI-48VDC-FL-2B
SMI-48VDC-FL-2C
SMI-48VDC-FL-2C
SMI-48VDC-SD-2A
SMI-48VDC-SD-2A
SMI-48VDC-SD-2B
SMI-48VDC-SD-2B
SMI-48VDC-SD-2C
SMI-48VDC-SD-2C
SMI-48VDC-SL-2A
SMI-48VDC-SL-2A
SMI-48VDC-SL-2B
SMI-48VDC-SL-2B
SMI-48VDC-SL-2C
SMI-48VDC-SL-2C
Номинальное рабочее напряжение, В555555555555666666666666999999999999121212121212121212121212181818181818181818181818242424242424242424242424363636363636363636363636484848484848484848484848
Серия: SMI-2P (14FD) (96)
  • Household appliance relay
На английском языке: Datasheet Songle Relay SMI-2P (14FD)
