Datasheet Songle Relay SMI-24VDC-FL-2B — Даташит
Производитель | Songle Relay |
Серия | SMI-2P (14FD) |
Модель | SMI-24VDC-FL-2B |
Реле для бытовых электроприборов
Datasheet SMI-2P
PDF, 3.7 Мб, Файл закачен: 22 фев 2018, Страниц: 2
Subminature High Power Relay 5A
![]() 9 предложений от 5 поставщиков Реле электромагнитное 24 В DPDT 2 формы C, 8 DIP, 13x29,2мм | |||
SMI-24VDC-SL-2C Реле | 136 ₽ | ||
SMI-24VDC-SL-2C Songle Relay | от 140 ₽ | ||
SMI-24VDC-SL-A Songle Relay | по запросу | ||
SMI-24VDC-SL-2C Songle Relay | по запросу |
Размеры | 28.9×12.6×20.6 мм |
Номинальное рабочее напряжение | 24 В |
Серия: SMI-2P (14FD) (96)
- SMI-05VDC-FD-2A SMI-05VDC-FD-2B SMI-05VDC-FD-2C SMI-05VDC-FL-2A SMI-05VDC-FL-2B SMI-05VDC-FL-2C SMI-05VDC-SD-2A SMI-05VDC-SD-2B SMI-05VDC-SD-2C SMI-05VDC-SL-2A SMI-05VDC-SL-2B SMI-05VDC-SL-2C SMI-06VDC-FD-2A SMI-06VDC-FD-2B SMI-06VDC-FD-2C SMI-06VDC-FL-2A SMI-06VDC-FL-2B SMI-06VDC-FL-2C SMI-06VDC-SD-2A SMI-06VDC-SD-2B SMI-06VDC-SD-2C SMI-06VDC-SL-2A SMI-06VDC-SL-2B SMI-06VDC-SL-2C SMI-09VDC-FD-2A SMI-09VDC-FD-2B SMI-09VDC-FD-2C SMI-09VDC-FL-2A SMI-09VDC-FL-2B SMI-09VDC-FL-2C SMI-09VDC-SD-2A SMI-09VDC-SD-2B SMI-09VDC-SD-2C SMI-09VDC-SL-2A SMI-09VDC-SL-2B SMI-09VDC-SL-2C SMI-12VDC-FD-2A SMI-12VDC-FD-2B SMI-12VDC-FD-2C SMI-12VDC-FL-2A SMI-12VDC-FL-2B SMI-12VDC-FL-2C SMI-12VDC-SD-2A SMI-12VDC-SD-2B SMI-12VDC-SD-2C SMI-12VDC-SL-2A SMI-12VDC-SL-2B SMI-12VDC-SL-2C SMI-18VDC-FD-2A SMI-18VDC-FD-2B SMI-18VDC-FD-2C SMI-18VDC-FL-2A SMI-18VDC-FL-2B SMI-18VDC-FL-2C SMI-18VDC-SD-2A SMI-18VDC-SD-2B SMI-18VDC-SD-2C SMI-18VDC-SL-2A SMI-18VDC-SL-2B SMI-18VDC-SL-2C SMI-24VDC-FD-2A SMI-24VDC-FD-2B SMI-24VDC-FD-2C SMI-24VDC-FL-2A SMI-24VDC-FL-2B SMI-24VDC-FL-2C SMI-24VDC-SD-2A SMI-24VDC-SD-2B SMI-24VDC-SD-2C SMI-24VDC-SL-2A SMI-24VDC-SL-2B SMI-24VDC-SL-2C SMI-36VDC-FD-2A SMI-36VDC-FD-2B SMI-36VDC-FD-2C SMI-36VDC-FL-2A SMI-36VDC-FL-2B SMI-36VDC-FL-2C SMI-36VDC-SD-2A SMI-36VDC-SD-2B SMI-36VDC-SD-2C SMI-36VDC-SL-2A SMI-36VDC-SL-2B SMI-36VDC-SL-2C SMI-48VDC-FD-2A SMI-48VDC-FD-2B SMI-48VDC-FD-2C SMI-48VDC-FL-2A SMI-48VDC-FL-2B SMI-48VDC-FL-2C SMI-48VDC-SD-2A SMI-48VDC-SD-2B SMI-48VDC-SD-2C SMI-48VDC-SL-2A SMI-48VDC-SL-2B SMI-48VDC-SL-2C
- Household appliance relay
SMI24VDCFL2B, SMI 24VDC FL 2B
