Datasheet EIC BAS15 — Даташит
| Производитель | EIC |
| Серия | BAS15 |
| Модель | BAS15 |
Высокоскоростной переключающий диод
TH97/10561QM BAS15 TW00/17276EM IATF 0060636
SGS TH07/1033 HIGH SPEED SWITCHING DIODE
DO -34 Glass FEATURES : High switching speed: max. 4 ns Continuous reverse voltage:max. 50 V Repetitive peak reverse voltage:max. 50 V Repetitive peak forward current:max. 225 mA. Pb / RoHS Free 1.00 (25.4)
min. 0.078 (2.0 )max. 0.118 (3.0)
max. Cathode
Mark 1.00 (25.4)
min. 0.017 (0.43)max. MECHANICAL DATA :
Case: DO-34 Glass Case
Weight: approx. 0.11g Dimensions in inches and ( millimeters ) Maximum Ratings and Thermal Characteristics (Rating at 25 В°C ambient temperature unless otherwise specified.)
Parameter Symbol Value Unit Maximum Repetitive Peak Reverse Voltage VRRM 50 V Maximum Continuous Reverse Voltage VRM 50 V IF 100 mA Maximum Repetitive Peak Forward Current IFRM 225 mA Maximum Power Dissipation PD 350 mW Maximum Non-repetitive Peak Forward Current at t < 1s, Tj = 25 В°C IFSM 0.5 A Maximum Junction Temperature TJ 200 В°C Storage Temperature Range TS -65 to + 200 В°C Maximum Continuous Forward Current , Ta = 150 В°C Electrical Characteristics
Parameter (Tj = 25В°C unless otherwise noted) Symbol Reverse Current IR Forward Voltage
Diode Capacitance VF
Cd Reverse Recovery Time Trr Page 1 of 2 Test Condition Min. Typ. Max. Unit VR = 50 V
VR = 50 V , Tj = 150 В°C
IF = 100 mA
f = 1MHz ; VR = 0
IF = 10 mA to I R = 60mA
RL = 100 О© ; Measured
at I R = 1 mA -200
100
1.1
2.0 nA -4 ns ОјA
V …
