Datasheet Texas Instruments CDCM61004RHBR/2801 — Даташит
СерияCDCM61004
МодельCDCM61004RHBR/2801
Тактовый генератор с тактовым сигналом 1:4 со сверхнизким джиттером 32-VQFN от -40 до 85
CDCM61004 Four Output, Integrated VCO, Low-Jitter Clock Generator datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 13 янв 2016
Микросхема Тактовый генератор, Clock Generator 21.875MHz to 28.47MHz Input 683.264MHz Output 32Pin VQFN EP T/R
CDCM61004RHBR/2801
250 ₽
CDCM61004RHBR/2801
406 ₽
Xinhuo Future
CDCM61004RHBR/2801
492 ₽
CDCM61004RHBR/2801
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка61004CDCM
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Input LevelCrystal,LVCMOS
Количество выходов4
Output Frequency(Max)683.264 МГц
Output Frequency(Min)43.75 МГц
Output LevelLVPECL, LVDS, LVCMOS
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
ProgrammabilityPin configuration
Special Features3.3V Vcc/Vdd
VCC Core3.3 В
VCC Out3.3 В
  • Evaluation Modules & Boards: CDCM6100XEVM
    CDCM61004/CDCM61002/CDCM61001 Evaluation Module
  • Fibre Channel and SAN Clock Generation Using the CDCM6100x
    PDF, 322 Кб, Файл опубликован: 18 фев 2009
    This application report is a guide for using Texas Instruments CDCM6100x in a Fibre Channel application as a clock distributor and clock synthesizer along with measured jitter performance results.
  • Using LVCMOS Input to the CDCM6100x
    PDF, 66 Кб, Файл опубликован: 23 май 2010
    This application report is a general guide for using LVCMOS inputs to the CDCM6100x series of ultra-low jitter clock generators from Texas Instruments. This document explains the basic connectivity of LVCMOS inputs to the CDCM6100x and recommends several methods for using the device that ensure proper operation.
  • TI Powers Altera's Arria II GX FPGA Development Kit
    PDF, 596 Кб, Файл опубликован: 29 сен 2009
  • Ethernet Clock Generation Using the CDCM6100x
    PDF, 454 Кб, Файл опубликован: 18 фев 2009
    This application report is a guide for using Texas Instruments CDCM6100x in an Ethernet LAN and WAN application as a clock distributor and clock synthesizer along with measured jitter performance results.
Серия: CDCM61004 (3)
  • Semiconductors > Clock and Timing > Clock Generators > Low Jitter <1psec RMS
На английском языке: Datasheet Texas Instruments CDCM61004RHBR/2801
