Datasheet Texas Instruments DAC5682ZIRGC — Даташит
СерияDAC5682Z
МодельDAC5682ZIRGC
Двухканальный, 16-разрядный, 1,0-GSPS, интерполяционный цифро-аналоговый преобразователь (ЦАП) 1x-4x 64-VQFN от -40 до 85
DAC5682Z 16-Bit, 1.0 GSPS 2x-4x Interpolating Dual-Channel Digital-to-Analog Converter (DAC) datasheet
PDF, 3.6 Мб, Версия: F, Файл опубликован: 20 янв 2015
Pin64
Package TypeRGC
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаDAC5682ZI
Width (мм)9
Length (мм)9
Thickness (мм).88
Pitch (мм).5
Max Height (мм)1
АрхитектураCurrent Sink
DAC Channels2
InterfaceParallel LVDS
Interpolation1x,2x,4x
Package GroupVQFN
Package Size: mm2:W x L64VQFN: 81 mm2: 9 x 9(VQFN) PKG
Power Consumption(Typ)1300 mW
Разрешение16 Bits
SFDR81 дБ
Sample / Update Rate1000 MSPS
  • Evaluation Modules & Boards: DAC5681EVM
    DAC5681 16-Bit, 1.0-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: DAC5681ZEVM
    DAC5681Z 16-Bit, 1.0-GSPS, 1x-4x Interpolating Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TRF3703-17EVM
    TRF3703-17 Evaluation Module
  • Evaluation Modules & Boards: DAC5682ZEVM
    DAC5682Z Dual-Channel, 16-Bit, 1.0-GSPS Digital-to-Analog Converter Evaluation Module
  • Evaluation Modules & Boards: TSW3100EVM
    TSW3100 Pattern Generator Module
  • Evaluation Modules & Boards: FMC-DAC-ADAPTER
    High Speed DAC to FMC (Xilinx) Header Adapter Card
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Design of Differential Filters for High-Speed Signal Chains (Rev. B)
    PDF, 166 Кб, Версия: B, Файл опубликован: 30 апр 2010
    Differential filters have many desirable attributes. The task of designing differential filters can seem daunting at first. Single-ended filters designed in any filter design package can be converted to a differential implementation. This application report explores simple conversion techniques for low-pass, high-pass, and band-pass LC filters.
  • Interfacing op amps to high-speed DACs, Part 1: Current-sinking DACs
    PDF, 319 Кб, Файл опубликован: 14 июл 2009
  • Passive Terminations for Current Output DACs
    PDF, 244 Кб, Файл опубликован: 10 ноя 2008
    The correct implementation of the high-speed DAC output termination is critical to achieving the best possible performance. The typical application involves choosing the correct network to create the necessary dc bias levels and correct effective impedance load to keep the output voltage within the compliance levels. This ensures that the maximum output signal amplitude and optimum ac performance
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • High Speed Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
Серия: DAC5682Z (3)
  • Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC5682ZIRGC
