Datasheet Texas Instruments DRA787BRGABFQ1 — Даташит
СерияDRA787
МодельDRA787BRGABFQ1
Процессор SoC с двойным DSP и EVE для аудиоусилителя 367-FCBGA -40 to 125
DRA78x Infotainment Applications Processor datasheet
PDF, 3.5 Мб, Версия: C, Файл опубликован: 12 июл 2017
Pin367
Package TypeABF
Industry STD TermFCBGA
JEDEC CodeS-PBGA-N
Package QTY90
CarrierJEDEC TRAY (5+1)
МаркировкаDRA787BRGABFQ1
Width (мм)15
Length (мм)15
Thickness (мм)2.39
Max Height (мм)2.82
ARM CPUN/A
CSI-2N/A
Co-Processor2 Dual ARM Cortex-M4 s
DSP2 C66x
DSP MHz750 Max.
Display Options1 LCD OUT,1 SD-DAC
EMAC1000,2-port 1Gb switch
EMIF1 DDR2,1 DDR3,1 DDR3L
Graphics AccelerationN/A
Hardware Accelerators1 Audio Tracking Logic
MMC/SD1x SDIO 4b
McASP3
Other On-Chip Memory512 KB
PCIe2 PCIe Gen2
Serial I/OCAN,CAN-FD,I2C,QSPI,SPI,UART
USBN/A
Video Input Ports1
  • Evaluation Modules & Boards: DRA78XEVM
    DRA78x Evaluation Module
  • Software Guidelines to EMIF/DDR3 Configuration on DRA7xx Devices
    PDF, 62 Кб, Файл опубликован: 12 июл 2017
    This application report provides information on EMIF/DDR configuration on dra7xx devices and guidelines to changes to be made in SPL/U-boot source code.
  • DRA74x_75x/DRA72x Performance
    PDF, 6.6 Мб, Файл опубликован: 17 июн 2016
    This application report provides information on the DRA74x_75x and DRA72x device throughput performances and describes the DRA74x_75x and DRA72x System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput perfor
  • Linux Boot Time Optimizations on DRA7xx Devices
    PDF, 197 Кб, Файл опубликован: 31 мар 2017
    This application report provides information on benchmarking and optimizing u-boot and Linux kernel on DRA7xx platform. It also demonstrates how to reach the userspace in less than 3 seconds from reset using generic boot time optimizations.
  • Flashing Binaries to DRA7xx Factory Boards Using DFU
    PDF, 42 Кб, Файл опубликован: 14 апр 2016
    This application report provides detailed procedures for flashing the binary images to eMMC Flash memory using Device Firmware Upgrade (DFU). Generally, the MMC/SD boot mode can be used to boot the fresh production board/EVM. In case there is not an external MMC/SD card available as part of production EVM or final product, this application report will be useful to flash the images to the factory b
  • Early Splash Screen on DRA7x Devices
    PDF, 721 Кб, Файл опубликован: 31 янв 2017
    This application report provides information on how to display a splash screen as soon as possible on the DRA7xx devices and perform a glitch-free transition from the splash screen to the full system UI. The steps in this document are demonstrated using U-Boot and Linux kernel. The same steps can be applied to other bootloaders and operating systems.
  • Interfacing DRA75x and DRA74x Audio to Analog Codecs (Rev. A)
    PDF, 57 Кб, Версия: A, Файл опубликован: 17 фев 2017
    DRA7xx Infotainment Application Processor offers an audio solution based on the multichannel audio serial port (McASP). McASP is a very flexible interface capable of interfacing with audio devices using protocols like Inter-IC Sound (I2S), PCM, TDM, S/PDIF. DRA7xx audio solution at LinuxВ® kernel level uses ALSA System-on-Chip (ASoC) layer with independent drivers for the DMA engine, CPU-side audio
  • Tools and Techniques for Audio Debugging
    PDF, 409 Кб, Файл опубликован: 13 апр 2016
    Debugging audio issues can be a challenging task due to the dynamic nature of the audio systems, in terms of runtime routing flexibility, gain control, and so forth. Investigating the root cause of system level issues is a difficult task without the appropriate tools and techniques.This document discusses some of the available tools for debugging audio issues. These tools span from TI-speci
  • Gstreamer Migration Guidelines
    PDF, 229 Кб, Файл опубликован: 26 апр 2016
    Gstreamer is a widely used multimedia framework. It is supported by GLSDK. New versions of gstreamer come out every month with a lot of bug fixes. The examples and steps are based on Gst 0.10 to Gst 1.2 migration. Anyone who wants to adapt to a newer or older version can use this as a guideline.The steps for creating and building a recipe are based on the yocto setup. The migration steps ar
  • Android Boot Optimization for IVI Systems
    PDF, 51 Кб, Файл опубликован: 29 фев 2016
    Boot-time optimizations are a critical component for a better Auto infotainment experience. This application report captures the details on how to improve android boot time and is meant to be a reference implementation. The end user (OEM/ODM/Customer/Product Owner) can review the optimizations that were tried and make a choice for the final product accordingly.
  • Using Peripheral Boot and DFU for Rapid Development on Jacinto 6 Devices
    PDF, 49 Кб, Файл опубликован: 15 фев 2017
    This application report describes how to use peripheral boot and Device Firmware Upgrade (DFU) to reduce the time required to load updated binaries to various cores of a Jacinto 6 (DRA7xx) family device.
  • Debugging Tools and Techniques With IPC3.x
    PDF, 353 Кб, Файл опубликован: 30 мар 2016
    There are several useful tools and techniques that enable you to debug issues encountered when using software that leverages IPC3.x. With some guidance on the tools and techniques, you can confidently debug the IPC and the remote core software.This application report guides the customers on the tools and techniques for debugging with IPC3.x
  • Modifying Memory Usage for IPUMM Applications Loaded IPC 3.x for DRA75x, DRA74x (Rev. A)
    PDF, 78 Кб, Версия: A, Файл опубликован: 15 янв 2016
    The default Image Processing Unit (IPU) image for DRA7xx IPU provides numerous capabilities for a rich multimedia experience. However, not all customers will want to use all of the capabilities, or may wish to add new capabilities. If not all of the capabilities are used, then the memory usage can be reduced. Similarly, if new capabilities are added, the memory usage can be increased.This d
  • Jacinto6 Spread Spectrum Clocking Configuration
    PDF, 113 Кб, Файл опубликован: 1 сен 2015
  • Using DSS Write-Back Pipeline for RGB-to-YUV Conversion on DRA7xx Devices
    PDF, 90 Кб, Файл опубликован: 14 авг 2017
    This application report provides information on how to use the DSS Write-back pipeline for RGB-to-YUV colorspace conversion on DRA7xx platform running Processor SDK Linux Automotive.
  • Quality of Service (QoS) Knobs for DRA74x, DRA75x & TDA2x Family of Devices (Rev. A)
    PDF, 148 Кб, Версия: A, Файл опубликован: 15 дек 2016
    This application report lists various quality-of-service (QoS) knobs that are implemented in DRA74x, DRA75x and TDA2x system-on-chip (SoC) family of devices. These QoS knobs aid to optimize overall system performance while running several concurrent application scenarios.
  • Optimizing DRA7xx and TDA2xx Processors for use with Video Display SERDES (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 14 июн 2017
    The purpose of this application report is to provide guidance on configuring DRA7xx and TDA2xx processors to meet video Serializer/Deserializer (SerDes) jitter requirements.
  • A Guide to Debugging With CCS on the DRA75x, DRA74x, TDA2x and TDA3x Family of D (Rev. A)
    PDF, 3.2 Мб, Версия: A, Файл опубликован: 19 авг 2016
    Being able to look into the state of the device when an application fails to run as expected is a key enabler while debugging the application. This application report walks through the different steps required to setup the TI Code Composer Studioв„ў (CCS), as well as how to debug applications on the DRA7x, TDA2x and TDA3x family of devices. The document starts with describing basic CCS debugging tec
  • Guide to fix Perf Issues Using QoS Knobs for DRA74x, DRA75x, TDA2x & TD3x Device
    PDF, 612 Кб, Файл опубликован: 13 авг 2014
    This application report provides a methodology through which performance issues can be identified and fixed in systems using DRA74x, DRA75x, TDA2x and TDA3x family of devices.
  • ECC/EDC on TDAxx (Rev. A)
    PDF, 109 Кб, Версия: A, Файл опубликован: 5 июл 2017
    TDA2x and TDA3x series of automotive processor are designed to be used in automotive safety systems. To enable safety, these processors come with error detection and correction (EDC) support for various memories. This application report provides an overview and usage description of EDC.
  • EMIF Tools (Rev. A)
    PDF, 207 Кб, Версия: A, Файл опубликован: 5 июн 2017
    At the center of every application is the need for memory. With limited on-chip processor memory, external memory serves as a solution for large software systems and data storage, and an unstable external memory interface can result in system failures or hinder software development. To prevent potential system level anomalies and ensure robust systems, hardware must be configured correctly and tes
Серия: DRA787 (2)
  • Semiconductors > Processors > Automotive Processors > DRAx Infotainment SoCs
На английском языке: Datasheet Texas Instruments DRA787BRGABFQ1
