Datasheet Texas Instruments DVC5416ZGU160IDWLD — Даташит
СерияTMS320VC5416
МодельDVC5416ZGU160IDWLD
Цифровой сигнальный процессор 144-BGA MICROSTAR от -40 до 100
TMS320VC5416 Fixed-Point Digital Signal Processor datasheet
PDF, 876 Кб, Версия: P, Файл опубликован: 13 окт 2008
Pin144144
Package TypeZGUZGU
Industry STD TermBGA MICROSTARBGA MICROSTAR
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY160160
CarrierEIAJ TRAY (5+1)EIAJ TRAY (5+1)
МаркировкаDVC5416ZGU160
Width (мм)1212
Length (мм)1212
Thickness (мм).9.9
Pitch (мм).8.8
Max Height (мм)1.41.4
ApplicationsCommunications and Telecom,Industrial
DSP1 C54x
DSP MHz120,160 Max.
Operating SystemsDSP/BIOS
Рабочий диапазон температурот -40 до 100 C
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
    XDS200 USB Debug Probe
  • Interfacing the ADS8361 to the TMS320VC5416 DSP
    PDF, 59 Кб, Файл опубликован: 5 дек 2002
    This application note presents a method for interfacing the ADS8361 16-bit SAR analog-to-digital converter to the TMS320VC5416в„ў DSP using McBSP1. The software developed reads 1024 samples continuously from the ADS8361. In an effort to reduce development time, the source code for this application note can be found on the Texas Instruments web site at http://www.ti.com. Search for document
  • TMS320VC5402A/VC5409A/VC5410A/VC5416 Bootloader (Rev. F)
    PDF, 310 Кб, Версия: F, Файл опубликован: 27 июн 2006
    This document describes the features and operation on the TMS320VC5402A, TMS320VC5409A, TMS320VC5410A, and TMS320VC5416 Digital Signal Processors. The contents of the on-chip ROM are discussed.Important Notice Regarding Bootloader Program Contents:Texas Instruments may periodically update the bootloader code supplied in the ROM to correct known problems, provide additional features,
  • Interface TSC Through McBSP
    PDF, 221 Кб, Файл опубликован: 28 окт 2004
    This application report develops and presents the methodology to interface TI's touch screen controller products and multichannel buffered serial ports (McBSP) through SPI and I2S buses. The interface software code is designed and tested using the TMS320VC5416 DSK and the TSC2100 EVM.
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
На английском языке: Datasheet Texas Instruments DVC5416ZGU160IDWLD
