Datasheet Texas Instruments F280041CPZS — Даташит
СерияTMS320F280041C
МодельF280041CPZS
Микроконтроллер Piccolo™ с InstaSPIN-FOC и CLB 100-LQFP -40 to 125
TMS320F28004x Piccoloв„ў Microcontrollers datasheet
PDF, 2.7 Мб, Версия: A, Файл опубликован: 22 авг 2017
30 предложений от 13 поставщиков
MICROCONTROLLER ARM CORTEX. C28x C2000TM C28x PiccoloTM Microcontroller IC 32-Bit 100MHz 128KB (128K x 8) FLASH 100-LQFP (14x14). Embedded...
F280041CPZS
166 ₽
F280041CPZS
310 ₽
Элитан
F280041CPZS
897 ₽
Hi-Tech Circuit Group
F280041CPZS
Pin100
Package TypePZ
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY90
CarrierJEDEC TRAY (10+1)
Width (мм)14
Length (мм)14
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADC21,14,12 Ch
ADC Resolution12-bit
CAN2
CPUC28x
Comparators7,6,5
DMA6 Ch
FPUYes
Flash128 KB
Тактовая частота100 МГц
High Resolution PWM16 Ch
I2C1
PGA/VGA7,5,4
PM Bus1
PWM16 Ch
Pin/Package100LQFP, 56VQFN, 64LQFP
QEP2,1
RAM100 KB
SPI2
Sigma-Delta Filter4,3
Total Processing100 MIPS
UART2 SCI
RoHSНе совместим
  • Evaluation Modules & Boards: TMDXDOCK280049M
    F280049M Experimenter's Kit for C2000 Real-Time Control Development Kits
  • A Technical Introduction to the TMS320F28004x Microcontroller
    PDF, 549 Кб, Файл опубликован: 23 мар 2017
    While many real-time control systems require a high-performance microcontroller (MCU), the tradeoffs of balancing performance and cost can be challenging. To this end, Texas Instruments developed the Piccoloв„ў TMS320F28004x MCU device series. This document discusses the technical details of the TMS320F28004x architecture and highlights the new improvements to various key peripherals, such as
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • TMS320C28x FPU Primer (Rev. A)
    PDF, 228 Кб, Версия: A, Файл опубликован: 20 июл 2009
    This primer provides an overview of the floating-point unit (FPU) in the C2000в„ў Delfino microcontroller devices.
  • Using PWM Output as a Digital-to-Analog Converter on a TMS320F280x (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 9 сен 2008
    This application report presents a method for utilizing the on-chip pulse width modulated (PWM) signal generators on the TMS320F280xв„ў family of digital signal controllers as a digital-to-analog converter (DAC). The method involves analog low-pass filtering the PWM signal to remove high frequency components, leaving only the low-frequency content. Theoretical and experimental results are presented
  • Running an Application from Internal Flash Memory on the TMS320F28xxx DSP (Rev. L)
    PDF, 641 Кб, Версия: L, Файл опубликован: 28 фев 2013
    Several special requirements exist for running an application from on-chip Flash memory on the TMS320F28xxx. These requirements generally do not manifest themselves during code development in RAM since the Code Composer Studioв„ў (CCS) debugger can mask problems associated with initialized sections and their linkage in memory. This application report covers the application software modificatio
  • Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)
    PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
    This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed.
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
Серия: TMS320F280041C (4)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
На английском языке: Datasheet Texas Instruments F280041CPZS
