Datasheet Texas Instruments HDC2010YPAR — Даташит
| Серия | HDC2010 |
| Модель | HDC2010YPAR |
Цифровой датчик влажности и температуры с низким энергопотреблением 6-DSBGA -40 до 85
HDC2010 Low Power Humidity and Temperature   Digital Sensors datasheet
PDF, 1.4 Мб, Файл опубликован: 16 июл 2017
 Купить HDC2010YPAR на РадиоЛоцман.Цены — от 36 до 277 ₽34 предложений от 12 поставщиков GEN 2 HUMIDITY SENSOR. Humidity Temperature Sensor 0 ~ 100% RH I²C ±2% 8s Surface Mount. Humidity, Moisture Sensors  | |||
| HDC2010YPAR Texas Instruments  | 71 ₽ | ||
| HDC2010YPAR Texas Instruments  | от 239 ₽ | ||
| HDC2010YPAR Texas Instruments  | по запросу | ||
| Pin | 6 |
| Package Type | YPA |
| Industry STD Term | DSBGA |
| JEDEC Code | S-XBGA-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | L |
| Pitch (мм) | .5 |
| Max Height (мм) | .675 |
| Mechanical Data | Скачать |
| Average Supply Current(Typ) | 0.55 @ 1 sample/sec uA |
| Interface | I2C |
| Rating | Catalog |
| Relative Humidity Accuracy(Typ) | В±2 %RH |
| Relative Humidity Operating Range(Typ) | 0 - 100 %RH |
| Напряжение питания | 3.6 Min |
| Temperature Accuracy(Typ) | 0.2 В°C |
- Evaluation Modules & Boards: HDC2010EVM
HDC2010 Low Power Humidity and Temperature Sensor Evaluation Module
- Optimizing Placement and Routing for Humidity Sensors (Rev. A)PDF, 1.3 Мб, Версия: A, Файл опубликован: 6 мар 2017
Humidity affects many properties of air, and of materials in contact with air. Water vapor is the key agentin both weather and climate, and it is an important atmospheric greenhouse gas. Humidity measurementsare used wherever there is a need to prevent condensation, corrosion, mold, warping or other spoilage ofproducts. This is highly relevant for foods, pharmaceuticals, chemicals, fuels, wo - AN-1112 DSBGA Wafer Level Chip Scale Package (Rev. AG)PDF, 13.7 Мб, Версия: AG, Файл опубликован: 12 авг 2015
Серия: HDC2010 (2)
- HDC2010YPAR HDC2010YPAT
- Semiconductors > Sensing Products > Humidity Sensors
