Линейка продуктов KEEN SIDE
Datasheet Texas Instruments HPA00141AIDCKG4 — Даташит
СерияOPA333
МодельHPA00141AIDCKG4
1.8V, 17ВµA, microPower, Precision, Zero-Drift CMOS Op Amp 5-SC70 -40 to 125
Datasheet OPA2333, OPA333
PDF, 2.2 Мб, Версия: E, Файл опубликован: 17 дек 2015, Страниц: 45
OPAx333 1.8-V, microPower, CMOS Operational Amplifiers, Zero-Drift
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаBQY
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Additional FeaturesEMI Hardened,Zero Drift
АрхитектураCMOS
CMRR(Min)106 дБ
CMRR(Typ)130 дБ
GBW(Typ)0.35 МГц
Input Bias Current(Max)200 pA
Iq per channel(Max)0.025 мА
Iq per channel(Typ)0.017 мА
Количество каналов1
Offset Drift(Typ)0.02 uV/C
Output Current(Typ)5 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)0.16 V/us
Total Supply Voltage(Max)5.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)55 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.01 мВ
  • Evaluation Modules & Boards: REF6025EVM-PDK
    REF6025 Voltage Reference Evaluation Module
  • New zero-drift amplifier has an IQ of 17 ОјA
    PDF, 357 Кб, Файл опубликован: 18 май 2007
  • OPA333, OPA2333 EMI Immunity Performance (Rev. A)
    PDF, 91 Кб, Версия: A, Файл опубликован: 31 окт 2012
  • EMI Rejection Ratio of Operational Amplifiers (With OPA333 and OPA333-Q1 as an E (Rev. A)
    PDF, 372 Кб, Версия: A, Файл опубликован: 1 июл 2015
    This application report introduces the concept of electromagnetic interference rejection ratio (EMIRR IN+) as a measure of the immunity of an operational amplifier to responding to electromagnetic interference (EMI). Texas Instruments has developed the ability to accurately measure and quantify the immunity of an operational amplifier over a broad frequency spectrum extending from 10 MHz to 6 GHz.
  • VCM vs. VOUT plots for instrumentation amplifiers with two op amps
    PDF, 632 Кб, Файл опубликован: 30 окт 2015
  • Zero-drift Amplifiers: Features and Benefits (Rev. A)
    PDF, 131 Кб, Версия: A, Файл опубликован: 9 фев 2017
  • 4Q 2015 Analog Applications Journal
    PDF, 1.6 Мб, Файл опубликован: 30 окт 2015
  • Offset Correction Methods: Laser Trim, e-Trim, and Chopper (Rev. A)
    PDF, 795 Кб, Версия: A, Файл опубликован: 20 июл 2017
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments HPA00141AIDCKG4
