Линейка продуктов KEEN SIDE
Datasheet Texas Instruments HPA00330AIDRLR — Даташит
СерияTMP102
МодельHPA00330AIDRLR
Датчик температуры с напряжением 1,4 В, интерфейсом I2C/SMBus и функцией оповещения в SOT-563 6-SOT-5X3 от -40 до 125
TMP102 Low-Power Digital Temperature Sensor With SMBus and Two-Wire Serial Interface in SOT563 datasheet
PDF, 950 Кб, Версия: F, Файл опубликован: 9 дек 2015
Pin6
Package TypeDRL
Industry STD TermSOT-5X3
JEDEC CodeR-PDSO-N
Package QTY4000
МаркировкаCBZ
Width (мм)1.2
Length (мм)1.6
Thickness (мм).55
Pitch (мм).5
Max Height (мм).6
Addresses4
InterfaceI2C, SMBus, 2-Wire
Iq(Typ)10 uA
Local Sensor Accuracy(Max)2 +/- C
Package GroupSOT-5X3
Package Size: mm2:W x L6SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) PKG
Special FeaturesProgrammable Alert,Fault Queue,One-Shot Conversion,Shutdown
Supply Current(Max)10 uA
Supply Current(Typ)10 uA
Supply Voltage(Max)3.6 В
Supply Voltage(Min)1.4 В
Temp Resolution(Max)12 bits
  • Evaluation Modules & Boards: TMP102EVM
    TMP102 Evaluation Module
  • Evaluation Modules & Boards: DIP-ADAPTER-EVM
    DIP Adapter Evaluation Module
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
На английском языке: Datasheet Texas Instruments HPA00330AIDRLR
