Datasheet Texas Instruments HPA00452RSTR — Даташит
СерияCC1150
МодельHPA00452RSTR
CC1150 Low Power Sub-1 GHz RF Transmitter datasheet
PDF, 1.9 Мб, Версия: B, Файл опубликован: 31 мар 2015
IC XMITTER RF MULTI-CHANNEL 16RS. Miscellaneous
Рутоника
HPA00452RSTR
HPA00452RSTR
Pin16
Package TypeRST
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
МаркировкаCC1150
Width (мм)4
Length (мм)4
Thickness (мм).85
Max Height (мм).95
Data Rate(Max)500 kbps
Device TypeSmart RF Transmitter
Frequency Bands315,433,779,868,915,920 МГц
Special FeaturesN/A
TX Power(Max)10 dBm
TechnologySub-1 GHz
Throughput(Max)0.5 Mbps
RoHSНе совместим
  • Daughter Cards: CC1150EMK-868
    CC1150EMK Evaluation Module 868 MHz
  • AN069 -- Low Cost Long Range One Way Audio Communications at 900 MHz (Rev. B)
    PDF, 302 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN012 -- Programming Output Powers on CC1100 and CC1150 (Rev. A)
    PDF, 511 Кб, Версия: A, Файл опубликован: 2 янв 2008
    This document gives a complete overview of the register settings required to adjust the output power of the CC1100/1 and CC1150 devices. The tables within this document include typical output power, harmonics, and current consumption at the different register settings.
  • DN025 -- Johanson Technology Matched Balun Filters (Rev. A)
    PDF, 609 Кб, Версия: A, Файл опубликован: 13 окт 2011
  • DN006 -- CC11xx Settings for FCC15.247 Solutions (Rev. B)
    PDF, 105 Кб, Версия: B, Файл опубликован: 17 авг 2010
  • AN049 -- Software for CC1100/CC2500 and MSP430 – Examples and Function Library
    PDF, 485 Кб, Файл опубликован: 31 май 2007
    The Software for CC1100/CC2500 and MSP430 - Examples and Function Library is the recommended starting point for developing software for the CC1100/CC2500 and MSP430 combination.The software demonstrates how to use some of the many advanced digital features and packet handling capabilities of the CC1100/CC2500. The software examples have been developed for the MSP430 Experimenter’s Board, but c
  • AN095 -- Continuous Data Streaming Applications - Using Serial Synchronous Mode (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 18 июл 2011
  • DN400 -- Interfacing CC1100 - CC2500 with MSP430 (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • DN017 -- CC11xx 868/915 MHz RF Matching (Rev. A)
    PDF, 328 Кб, Версия: A, Файл опубликован: 31 мар 2008
    There are three versions of the CC11xx reference design which have been published. This design note gives a short introduction to RF matching and important aspects when designing products using the CC11xx parts and discusses the differences between the three reference design revisions.
  • DN501 -- PATABLE Access (Rev. B)
    PDF, 66 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN500 -- Packet Transmission Basics (Rev. C)
    PDF, 174 Кб, Версия: C, Файл опубликован: 6 апр 2009
  • DN503 -- SPI Access (Rev. B)
    PDF, 94 Кб, Версия: B, Файл опубликован: 22 окт 2007
    The purpose of this design note is to show how the serial peripheral interface (SPI) must be configured to be able to communicate with the CC1100/CC1101/CC1150/CC2500/CC2550. It also shows how the status bytes should be interpreted and how SW reset is done over the SPI interface.
  • AN072 -- Using the TAI-SAW TA0801A SAW Filter and External PA (Rev. A)
    PDF, 359 Кб, Версия: A, Файл опубликован: 19 авг 2009
  • DN506 -- GDO Pin Usage (Rev. A)
    PDF, 219 Кб, Версия: A, Файл опубликован: 22 окт 2007
    The purpose of this design note is to explain how to use the different general digital output (GDO) pins for control and monitoring purposes. The focus is set on interfacing with a microcontroller unit (MCU) and is related to the CC1100, CC1101, CC1150, CC2500 and CC2550 devices.
  • DN300 -- SmartRF04EB Troubleshooting (Rev. B)
    PDF, 490 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN504 -- FEC Implementation (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 22 окт 2007
    This design note explains the functionality of forward error correction (FEC) and how it is used in the CC1100, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices. Example code for FEC implementation is included.
  • DN032 -- Options for Cost Optimized CC11xx Matching
    PDF, 112 Кб, Файл опубликован: 25 авг 2010
  • DN016 -- Compact Antenna Solution for 868/915 MHz (Rev. B)
    PDF, 832 Кб, Версия: B, Файл опубликован: 20 авг 2009
  • DN507 -- FEC Decoding
    PDF, 264 Кб, Файл опубликован: 28 янв 2010
    The purpose of this design note is to show how the FEC decoding implemented in HW on the CC1100, CC1100E, CC1101, CC1110Fx, CC1111Fx, CC1150, CC2500, CC2510Fx, CC2511Fx, and CC2550 can be implemented in SW. This is in particular very important for the CC430Fx device, which has the same radio as the CC1101 and CC1110/11Fx but without HW FEC included.
  • AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)
    PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • AN001 -- SRD regulations for license free transceiver operation
    PDF, 260 Кб, Файл опубликован: 1 фев 2006
  • DN303 -- Cleanup of Installed PC Tools
    PDF, 545 Кб, Файл опубликован: 20 дек 2006
  • DN033 - Mitsubishi Ceramic Antenna for 868 MHz, 915 MHz & 955 (Rev. A)
    PDF, 685 Кб, Версия: A, Файл опубликован: 14 сен 2010
  • DN023 -- 868 MHz, 915 MHz and 955 MHz Inverted F Antenna (Rev. C)
    PDF, 369 Кб, Версия: C, Файл опубликован: 30 авг 2011
  • AN028 -- LC Filter with Improved High-Frequency Attenuation
    PDF, 254 Кб, Файл опубликован: 1 фев 2006
    AN028 -- Improved LC Filter
  • AN014 -- Frequency Hopping Systems
    PDF, 210 Кб, Файл опубликован: 1 фев 2006
  • AN021 -- Voltage Level Conversion
    PDF, 212 Кб, Файл опубликован: 1 фев 2006
  • DN011 -- RF Module Testing using SmartRF Studio (Rev. A)
    PDF, 325 Кб, Версия: A, Файл опубликован: 23 мар 2009
  • DN018 -- Range Measurements in an Open Field Environment (Rev. A)
    PDF, 607 Кб, Версия: A, Файл опубликован: 15 апр 2008
    This design note is a general description of how to set up open field range measurements and what has to be considered. Applies to all low power RF-ICs.
  • DN002 -- Practical Sensitivity Testing
    PDF, 364 Кб, Файл опубликован: 20 дек 2006
  • AN003 -- SRD Antennas
    PDF, 358 Кб, Файл опубликован: 1 фев 2006
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • Semiconductors > Wireless Connectivity > Companion Wireless Solutions > Smart RF Transceivers
На английском языке: Datasheet Texas Instruments HPA00452RSTR
