Datasheet Texas Instruments HPA00537PWPRG4 — Даташит
СерияTLC5941
МодельHPA00537PWPRG4
16-канальный светодиодный драйвер с точечной коррекцией и ШИМ-управлением в оттенках серого 28-HTSSOP
16 Channel LED Driver w/DOT Correction and Grayscale PWM Control datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 3 янв 2008
, 16Channel LED Driver with Dot Correction and Grayscale PWM Control 28-HTSSOP
HPA00537PWPRG4
115 ₽
HPA00537PWPRG4
118 ₽
Xinhuo Future
HPA00537PWPRG4
121 ₽
HPA00537PWPRG4
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTLC5941
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Analog Dimming Steps64
Ch to Ch Accuracy(Typ)1 +/- %
Data Transfer Rate(Typ)30 МГц
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Special FeaturesError Flag,Fault Detection,LED Open Detection,Power Good
  • Using the TLC5940 with Higher LED Supply Voltages and Series LEDs
    PDF, 353 Кб, Файл опубликован: 20 авг 2007
    This application report describes how to accommodate higher LED supply voltages and increase the number of series LEDs that the TLC5940 can drive.
  • Grayscale and Dot-Corrected LED Display Using TLC5941 (Rev. A)
    PDF, 198 Кб, Версия: A, Файл опубликован: 5 мар 2008
    The TLC5941 LED driver uses a serial data interface to receive grayscale and dot correction data. This application report discusses the hardware and firmware to drive the TLC5941 with a MSP430F427 microcontroller.
  • LED Driver--Paralleled Outputs Provide High Current Outputs
    PDF, 957 Кб, Файл опубликован: 25 сен 2006
    This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments HPA00537PWPRG4
