Datasheet Texas Instruments HPA00612IYZGR — Даташит
Серия | TSC2007 |
Модель | HPA00612IYZGR |
Контроллер сенсорного экрана Nano-Power с последовательным интерфейсом I2C 12-DSBGA -40 to 85
Nano-Power Touch Screen Controller with IВІCв„ў Serial Interface datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 2 мар 2009
Pin | 12 |
Package Type | YZG |
Industry STD Term | DSBGA |
JEDEC Code | R-XBGA-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | TSC2007I |
Thickness (мм) | .375 |
Pitch (мм) | .5 |
Max Height (мм) | .625 |
Mechanical Data | Скачать |
Control Interface | I2C |
Тип входа | Differential,Single-Ended |
Package Group | DSBGA |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Rating | Catalog |
SAR ADC Resolution | 12 Bits |
SAR Sample Rate(Max) | 154 kSPS |
Supply Voltage (Analog) | 1.2 Max |
Supply Voltage (I/O VDD) | 3.6 Min |
Touch Panel | 4-Wire |
Vref | Ext Int/Ext |
- Evaluation Modules & Boards: TSC2007EVM
TSC2007EVM Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: TSC2007EVM-PDK
TSC2007EVM Evaluation Module-PDK
- TSC2007 Linux DriverPDF, 120 Кб, Файл опубликован: 31 мар 2009
This application report describes the LinuxВ® operating system driver for the TSC2007 to help customers implement designs using the TSC2007 touch-screen controller. It also discusses the driver and associated code. The Linux driver code can be integrated into a customer's software system under different host processors. This driver has been tested and used on the Atmel AT91SAM9261EK platform. - TSC2007 WinCEВ® 5.0 DriverTSP, Файл опубликован: 31 мар 2009
The TSC2007 Microsoft WindowsВ® CE (WinCE) 5.0 touch driver was developed with an IВІCв„ў control interface; the code has been tested on a Samsung SC32442 application processor. This application report discusses the TSC2007 driver, including the hardware connection between the TSC2007 and the platform, the WinCE 5.0 driver code structure, and the installations. - TSC2007 WinCE 6.0 Touch DriversTSP, Файл опубликован: 29 апр 2009
The TSC2007 Microsoft WindowsВ® CE (WinCE) 6.0 touch driver was developed with an IВІCв„ў control interface; the code has been tested on a Samsung SC32442 application processor. This application report discusses the TSC2007 driver, including the hardware connection between the TSC2007 and the platform, the WinCE 6.0 driver code structure, and the installations. - Migrating from TSC2003 to TSC2007PDF, 169 Кб, Файл опубликован: 17 июл 2007
This application report describes the issues of interest related to migrating from the Texas Instruments (TI) TSC2003 to the TSC2007 touch screen controller. The objective is to highlight differences between the two devices and to provide guidelines for hardware and software changes required for the migration. - Important Considerations to Assure a Safe PORPDF, 115 Кб, Файл опубликован: 10 мар 2009
This application report explains specific and important considerations related to the automatic power-on reset feature of the TSC2007 touch-screen controller. It also discusses several possible issues that may arise as a result of improperly powering the device on or off, and provides application solutions to ensure proper TSC2007 operation under various power-supply conditions. - Q2 2008 Issue Analog Applications JournalPDF, 1.3 Мб, Файл опубликован: 16 май 2008
This document holds articles for specific application examples and technologies. It also includes a selection guide for antennas in low-power RF applications. - Using a touch-screen controller’s auxiliary inputsPDF, 149 Кб, Файл опубликован: 12 окт 2007
- Operation Schemes of Touch Screen ControllersPDF, 846 Кб, Файл опубликован: 21 май 2007
- PCB Layout Guideline for TI Resistive TSC DevicesPDF, 144 Кб, Файл опубликован: 4 окт 2012
- Reducing Analog Input Noise in Touch Screen Systems (Rev. A)PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present - Calibration in touch-screen systemsPDF, 169 Кб, Файл опубликован: 10 авг 2007
- Q4 2007 Issue Analog Applications Journal (Rev. A)PDF, 316 Кб, Версия: A, Файл опубликован: 14 ноя 2007
- Apply TI TSC for Various and Multiple FunctionsPDF, 316 Кб, Файл опубликован: 11 дек 2006
This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
Серия: TSC2007 (8)
- Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
