Datasheet Texas Instruments HPA00742DBTR — Даташит
СерияBQ20Z90-V150
МодельHPA00742DBTR
Газовый манометр, совместимый с SBS v1.1, для использования с bq29330 30-TSSOP от -40 до 85
SBS v1.1 Compliant Gas Gauge for Use With the bq29330* datasheet
PDF, 690 Кб, Файл опубликован: 28 июн 2007
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
МаркировкаBQ20Z90
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Evaluation Modules & Boards: BQ20Z90EVM-001
    BQ20Z90EVM Evaluation Module for 2nd Generation Impedance TrackВ™
  • Evaluation Modules & Boards: BQMTESTER
    BQMTESTER Multi Channel Test and Program Board
  • Evaluation Modules & Boards: BQTESTER
    Single Channel Tester
  • bq20z90-V110 to bq20z90-V150 Change List
    PDF, 34 Кб, Файл опубликован: 11 янв 2008
    bq20z90-V150 Design Considerations
  • bq29330 External Short Circuit Protection
    PDF, 155 Кб, Файл опубликован: 22 авг 2007
    In Li-ion battery pack design, short-circuit protection should be given sufficient emphasis to ensure that even if an external pack short does occur, it is benign. Properly designed battery fuel gauge solutions using the bq29330 analog front-end (AFE) protector and bq20z70, bq20z75, bq20z90, and bq20z95 fuel gauge ICs not only safeguards the battery, but also ensures a full recovery of functionali
  • Fast Cell Balancing Using External MOSFET (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 26 янв 2009
    The need for cell balancing comes from the fact that cell-to-cell differences in self-discharge, capacity, and impedance can lead to different charge states among the cells. However, the charger terminates the charge based on the summed voltage only, which may leave some cells undercharged and others overcharged. To remedy this imbalance and to achieve the goal of having all cells reaching 100% st
  • 2-Series-Cell Considerations for Advanced Fuel Gauges
    PDF, 154 Кб, Файл опубликован: 9 май 2008
  • bq20z80 EVM Data Flash Settings for Num of Serial Cells/Pack Cap (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 ноя 2006
    This application report describes the configuration changes in the data flash constants in the Texas Instruments bq20z80 Gas Gauge Evaluation Software for a variety of battery-pack configurations.
  • Operating Fuel Gauge bq20z7x/8x/9x and SMBus-Like bq24745/47/65 Chargers
    PDF, 132 Кб, Файл опубликован: 6 окт 2009
    The smart charger bq24747/765 is a high-efficiency, synchronous battery charger with an integrated input current comparator. This charger provides low component count for space constrained, multichemistry battery charging applications. SMBus input current, charge current, and input current digital-to-analog converters allow for very high regulation accuracies that the system power management micr
  • bq20z70 and bq20z90 Application Book
    PDF, 14.2 Мб, Файл опубликован: 13 дек 2006
    This document introduces the bq20z70/z90 Impedance Trackв„ў and bq29330 chipset gas gauge solution
  • Updating Firmware With the bq20zxx and EVM (Rev. B)
    PDF, 54 Кб, Версия: B, Файл опубликован: 7 ноя 2006
    This application report presents the steps necessary to update the bq20z80 firmware and the EVM.
  • Pack Assembly and the bq20zxx (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 7 ноя 2006
    This application report describes a recommended assembly sequence for the bq20z80-based battery pack. This procedure results in the most time-efficient setup of the battery pack. Included are steps for connecting a 4-series cell battery to the bq20z80EVM-001.
  • Cell Balancing Using the bq20zxx (Rev. C)
    PDF, 208 Кб, Версия: C, Файл опубликован: 12 янв 2011
    This application report discusses three types of cell imbalances that are observed in a battery pack withserially connected cells.
  • Cell-type Specific Settings for Cell Imbalance Permanent Failure Thresholds
    PDF, 100 Кб, Файл опубликован: 28 сен 2007
  • Quick-Start Guide for bq20zxx Family Gas Gauges (Rev. A)
    PDF, 4.4 Мб, Версия: A, Файл опубликован: 4 сен 2007
    The intent of this application report is to give the user an overview of the design process, how to use the evaluation module and software, and to provide helpful troubleshooting techniques.This document begins with setting up the evaluation module and working with bq Evaluation Software. Several tips for troubleshooting the software connection are included, as well as navigation and what to l
  • Design 4: Support of Multiple Li-Ion Chemistries w/Impedance Track(TM) Gas Gauge (Rev. R)
    PDF, 87 Кб, Версия: R, Файл опубликован: 15 окт 2009
  • Thermistor Coefficient Calculator for TI Advanced Fuel Gauges
    PDF, 58 Кб, Файл опубликован: 4 окт 2006
  • Wide-Vin Battery-Charger Using SMBus MSP430 MCUs and bq Fuel Gauges (Rev. A)
    PDF, 1.0 Мб, Версия: A, Файл опубликован: 25 июл 2011
    This application report describes a smart-battery charger reference design with a wide-input-voltage range. The reference design implements the System Management Bus (SMBus) protocol for communication between the MSP430 microcontroller and a SMBus-compatible battery fuel gauge. The MSP430 device interrogates the fuel gauge for voltage, current, and other parameters via SMBus. It then adjusts the p
  • Semiconductors > Power Management > Battery Management Products > Battery Fuel Gauge
На английском языке: Datasheet Texas Instruments HPA00742DBTR
