Datasheet Texas Instruments HPA00810-2/2 — Даташит
СерияTPS61161
МодельHPA00810-2/2
Драйвер белого светодиода с цифровой регулировкой яркости и ШИМ в корпусе WSON размером 2 x 2 мм 6-WSON от -40 до 85
TPS6116x White LED Drivers With Digital and PWM Brightness Control in 2-mm x 2-mm WSON Package datasheet
PDF, 1.7 Мб, Версия: E, Файл опубликован: 14 июл 2016
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаBZR
Width (мм)2
Length (мм)2
Thickness (мм).75
Max Height (мм).8
Количество каналов1
Duty Cycle(Max)93 %
LED10
LED Current Per Channel20 мА
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Peak Efficiency90 %
Shutdown Current(Typ)1 uA
Special FeaturesEasyScale 1-Wire Interface,Load Disconnect During Shutdown
Switching Frequency(Max)600 kHz
TopologyBoost
ТипInductive
Vin(Max)18 В
Vin(Min)2.7 В
Vout(Max)38 В
Vout(Min)2.7 В
  • Evaluation Modules & Boards: TPS61161EVM-243
    TPS61161EVM-243 Evaluation Module
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • TPS6116x With Separate Power Stage and IC Input Voltages
    PDF, 194 Кб, Файл опубликован: 2 апр 2009
    This application report shows how to operate the TPS6116x integrated circuits (IC) with two separate input power rails, one for the boost power stage and one to power the IC itself. In this example, an input as low as 1.8 V from discharged dual-alkaline batteries supplies power to the boost stage, whereas a separate 3.3-V supply powers the IC.
  • Simple Backlight Driver Dimming Performance
    PDF, 74 Кб, Файл опубликован: 20 мар 2017
    The TPS61158, TPS61160/61, TPS61162/63A, TPS61165, and TPS61169 (hereafter TPS611xx) are simple backlight drivers commonly used in smartphones and tablets. These devices support PWM dimming with an input voltage as low as 2.7 V. This application note discusses the requirements for using tje TPS611xx parts at the lowest performance specifications for PWM dimming.
  • Extending the Input Voltage Range of the TPS6116x/8x/9x WLED Drivers
    PDF, 124 Кб, Файл опубликован: 12 авг 2009
    The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available
  • How to Use Analog Dimming With TPS6116x
    PDF, 162 Кб, Файл опубликован: 5 авг 2011
    The TPS6116x family of devices are simple, white LED drivers that can drive up to 10 LEDs in series. The CTRL pin on these devices is the input for the integrated analog dimming circuitry but can only be used for PWM signals switching higher than 5 kHz. This application report shows a simple, external circuit that can be used to perform analog dimming from PWM signals that are below 5 kHz as well
  • Inductor Selection in Boost Converters for LCD Backlight Applications
    PDF, 764 Кб, Файл опубликован: 24 окт 2016
    White LED drivers for LCD back-light applications are often designed for battery-powered devices. This makes circuit size and efficiency crucial. Because of this, selecting the optimal inductor is one of the mostimportant aspects of the design. This application note discusses the important parameters of the inductorand how to select the right inductor for the application.
  • Schottky Diode Selection in Asynchronous Boost Converters
    PDF, 491 Кб, Файл опубликован: 6 сен 2016
    Asynchronous boost converters require a Schottky diode as the rectifying element due to the diode's lowforward voltage and fast turn-on time. Because of these characteristics asynchronous boost converterscan have as good as, or better efficiency, than synchronous boost converters. This is especially true whenthe boost conversion ratios (VOUT/VIN) are high, and the Schottky diode conduction t
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
  • Reducing radiated EMI in WLED drivers
    PDF, 945 Кб, Файл опубликован: 14 июл 2009
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
HPA008102/2, HPA00810 2/2
На английском языке: Datasheet Texas Instruments HPA00810-2/2
