Datasheet Texas Instruments HPA00810ADRVR-2/2 — Даташит
СерияTPS61161A
МодельHPA00810ADRVR-2/2
Драйвер белого светодиода с ШИМ-регулированием яркости в корпусе WSON размером 2 x 2 мм.
TPS6116xA White LED Driver with PWM Brightness Control in 2-mm x 2-mm WSON Package datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 14 июл 2016
До 10 светодиодов в серии 6-WSON от -40 до 85
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаOBT
Width (мм)2
Length (мм)2
Thickness (мм).75
Max Height (мм).8
Количество каналов1
Duty Cycle(Max)93 %
LED10
LED Current Per Channel20 мА
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Peak Efficiency90 %
Shutdown Current(Typ)0.7 uA
Special FeaturesEasyScale 1-Wire Interface,Load Disconnect During Shutdown
Switching Frequency(Max)600 kHz
TopologyBoost
ТипInductive
Vin(Max)18 В
Vin(Min)2.7 В
Vout(Max)38 В
Vout(Min)2.7 В
  • TPS6116x With Separate Power Stage and IC Input Voltages
    PDF, 194 Кб, Файл опубликован: 2 апр 2009
    This application report shows how to operate the TPS6116x integrated circuits (IC) with two separate input power rails, one for the boost power stage and one to power the IC itself. In this example, an input as low as 1.8 V from discharged dual-alkaline batteries supplies power to the boost stage, whereas a separate 3.3-V supply powers the IC.
  • Extending the Input Voltage Range of the TPS6116x/8x/9x WLED Drivers
    PDF, 124 Кб, Файл опубликован: 12 авг 2009
    The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available
Серия: TPS61161A (3)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
HPA00810ADRVR2/2, HPA00810ADRVR 2/2
На английском языке: Datasheet Texas Instruments HPA00810ADRVR-2/2
