Datasheet Texas Instruments HPA00850DCUR — Даташит
Серия | SN74CB3T3306 |
Модель | HPA00850DCUR |
Транслятор напряжения с двойным переключателем шины 8-VSSOP от -40 до 85
SN74CB3T3306 Dual FET Bus Switch 2.5-V/3.3-V Low-Voltage Bus Switch With 5-V Tolerant Level Shifter datasheet
PDF, 895 Кб, Версия: C, Файл опубликован: 31 дек 2015
Pin | 8 | 8 | 8 | 8 | 8 |
Package Type | DCU | DCU | DCU | DCU | DCU |
Industry STD Term | VSSOP | VSSOP | VSSOP | VSSOP | VSSOP |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 3000 | 3000 | 3000 | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | WA6Q | A6 | WA6R | WZ | WR |
Width (мм) | 2 | 2 | 2 | 2 | 2 |
Length (мм) | 2.3 | 2.3 | 2.3 | 2.3 | 2.3 |
Thickness (мм) | .85 | .85 | .85 | .85 | .85 |
Pitch (мм) | .5 | .5 | .5 | .5 | .5 |
Max Height (мм) | .9 | .9 | .9 | .9 | .9 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать | Скачать |
Additional Features | Powered off protection,Signal path Translation |
Полоса частот | 100 МГц |
Configuration | 1:1 SPST |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 4.5 пФ |
Input/Output ON-state Capacitance(Typ) | 4 пФ |
Количество каналов | 2 |
OFF-state leakage current(Max) | 10 мкА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) PKG |
Rating | Catalog |
Ron(Max) | 8 Ohms |
Ron(Typ) | 5 Ohms |
Supply Current(Max) | 20 uA |
Supply Range | 3.6 Max |
VIH(Min) | 1.7 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 3.6 В |
Vdd(Min) | 2.3 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- CBT-C, CB3T, and CB3Q Signal-Switch FamiliesPDF, 584 Кб, Файл опубликован: 4 фев 2003
Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot - Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
In today?s competitive computing and networking industry, any equipment downtime due to component interconnects or bus failures impedes communication, hinders productivity and hampers financial growth. In recognizing this increasingly costly unplanned downtime, the industry introduced live-insertion technology to minimize the impact of any such failures. The live-insertion feature enables a networ - How to Select Little Logic (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
Серия: SN74CB3T3306 (5)
- 74CB3T3306DCURE4 74CB3T3306DCURG4 HPA00850DCUR SN74CB3T3306DCTR SN74CB3T3306DCUR
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
