Datasheet Texas Instruments HPA01055DRBR — Даташит
СерияUCC24610
МодельHPA01055DRBR
Контроллер синхронного выпрямителя вторичной стороны 8-SON от -40 до 125
UCC24610 GREEN Rectifierв„ў Controller Device datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 12 авг 2015
Package TypeDRB
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
Маркировка4610
Width (мм)3
Length (мм)3
Thickness (мм).88
Max Height (мм)1
Frequency(Max)600 kHz
Package GroupSON
Package Size: mm2:W x LSee datasheet (SON) PKG
Special FeaturesSYNC pin for CCM
UVLO Thresholds On/Off4.4/4.2 В
  • Evaluation Modules & Boards: UCC24610EVM-693
    Diode Replacement Demonstration Card for UCC24610 Secondary Side Synchronous Rectifier Controller
  • Evaluation Modules & Boards: UCC24610EVM-563
    Evaluation Module for UCC24610 Secondary Side Synchronous Rectifier Controller
  • A High Efficiency Synchronous Rectifier Flyback for High Density AC/DC Adapter
    PDF, 1.1 Мб, Файл опубликован: 3 июн 2011
    With the fast development of the tablet PC, the increasing load demand requires the adapter to have high power density, high efficiency, and low profile. This application note presents a high efficiency Flyback converter with output synchronous rectification, which can achieve high efficiency within a wide load range to meet the high density requirements. By using Texas Instrument’s UCC28610 gree
  • High-efficiency AC adapters for USB charging
    PDF, 184 Кб, Файл опубликован: 31 янв 2012
  • 1Q 2012 Issue Analog Applications Journal
    PDF, 2.4 Мб, Файл опубликован: 31 янв 2012
Серия: UCC24610 (5)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Synchronous Rectifier
На английском языке: Datasheet Texas Instruments HPA01055DRBR
