Datasheet Texas Instruments HPA01116RHBR — Даташит
СерияTLC5947
МодельHPA01116RHBR
24-канальный 12-битный светодиодный драйвер ШИМ с внутренним генератором 32-VQFN от -40 до 85
TLC5947 24-Channel, 12-Bit PWM LED Driver With Internal Oscillator datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 14 янв 2015
, 24Channel, 12Bit PWM LED Driver with Internal Oscillator 32-VQFN -40℃ to 85℃
HPA01116RHBR
184 ₽
HPA01116RHBR
194 ₽
Hi-Tech Circuit Group
HPA01116RHBR
HPA01116RHBR
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка5947TLC
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Ch to Ch Accuracy(Typ)2 +/- %
Data Transfer Rate(Typ)30 МГц
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Special FeaturesInternal GS Clock,Thermal Shutdown
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments HPA01116RHBR
