Datasheet Texas Instruments HPA02141ERTER — Даташит
СерияTS3A225E
МодельHPA02141ERTER
Автономный аудиопереключатель с определением типа гарнитуры 16-WQFN от -40 до 85
Autonomous Audio Headset Switch datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 29 май 2013
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаZTL
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Additional FeaturesAutonomous Detection (3 or 4 poles),Integrated Codec Sense Line,Manual I2C Control,Manual Microphone Switch Control
Configuration2 X SPDT
Input/Ouput Voltage(Max)4.5 В
Input/Ouput Voltage(Min)-2 В
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 9 mm2: 3 x 3(WQFN) PKG
Ron(Typ)0.07,0.1 Ohms
VCC(Max)4.5 В
VCC(Min)2.7 В
  • Evaluation Modules & Boards: BOOSTXL-AUDIO
    Audio Signal Processing BoosterPack Plug-In Module
  • Support Selfie Sticks Using a TS3A227E Audio Jack Switch
    PDF, 229 Кб, Файл опубликован: 4 мар 2016
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3A225E (4)
  • Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
На английском языке: Datasheet Texas Instruments HPA02141ERTER
