Datasheet Texas Instruments HPA02153A1DRBR — Даташит
Серия | TPA6205A1 |
Модель | HPA02153A1DRBR |
1.25-W Mono, Fully Differential, Class-AB Audio Amp w/ 1.8V Compatible Shutdown Voltage (TPA6205) 8-SON -40 to 85
TPA6205A1 1.25-W Mono Fully Differential Audio Power Amplifier With 1.8-V Input logic Thresholds datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 30 ноя 2015
Купить HPA02153A1DRBR на РадиоЛоцман.Цены — от 33 до 34 ₽ Audio Amplifiers Order MFG part # TPA6205A1DRBR | |||
HPA02153A1DRBR Texas Instruments | 33 ₽ | ||
HPA02153A1DRBR Texas Instruments | 34 ₽ | ||
HPA02153A1DRBR Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | DRB |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | AAOI |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .88 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Analog Supply (V) | 5.5 Min |
Архитектура | Class AB |
Audio Input Type | Analog Input |
Control Interface | Hardware |
Iq per channel(Typ) | 1.7 мА |
Iq(Max) | 2 мА |
Iq(Typ) | 1.7 мА |
Load(Min) | 8 ohms |
Выходная мощность | 1.25 W |
PSRR | 90 дБ |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Pin/Package | 8BGA MICROSTAR JUNIOR, 8MSOP-PowerPAD, 8SON |
Rating | Catalog |
Shutdown Current (ISD) | 0.01 uA |
Speaker Channels | Mono Max |
THD + N @ 1 kHz | 0.06 % |
- Evaluation Modules & Boards: TPA6205A1EVM
TPA6205A1 Evaluation Module (EVM)
- Single-Ended Input Pop Reduction for TPA6203A1PDF, 651 Кб, Файл опубликован: 23 июл 2009
Серия: TPA6205A1 (10)
- Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
