Datasheet Texas Instruments LM36010YKBR — Даташит
СерияLM36010
МодельLM36010YKBR
LM36010 Синхронный повышающий светодиодный драйвер вспышки 8-DSBGA -40 до 85
LM36010 Synchronous-Boost, Single-LED Flash Driver With 1.5-A High-Side Current Source datasheet
PDF, 3.3 Мб, Версия: A, Файл опубликован: 20 июл 2017
Package TypeYKB
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка6010
Width (мм).805
Length (мм)1.555
Thickness (мм).345
Pitch (мм).35
Max Height (мм).5
Iout(Max)1.5 A
Iq(Typ)0.3 мА
LED1
Package GroupDSBGA
Special FeaturesI2C Control,OVP,Synchronous Rectification
Vin(Max)5.5 В
Vin(Min)2.5 В
  • Evaluation Modules & Boards: LM36010EVM
    Synchronous Boost 1LED Flash Driver W/ 1.5A High-Side Current Source Evaluation Module
  • Using Flash LED Drivers for Infrared (IR) LED Applications
    PDF, 163 Кб, Файл опубликован: 20 мар 2017
    The LM3643/4/8 devices are commonly used for mobile phone flash LED drivers. This application notediscusses the general applications of IR in mobile devices as well as the behavior of TI’s LM364X devicesfor such applications.These LED flash drivers are small solutions that provide a maximum of 1.5 A to one or two LEDs in eitherpass mode, where the current sources are connected to the input
  • LED Flash-Protection Features
    PDF, 33 Кб, Файл опубликован: 23 авг 2017
    Modern LED camera flash drivers are feature-rich and power dense. Capable of delivering over 2 A ofcurrent to dual LEDs in packages as small as 1.69 mm Г— 1.31 mm, flash LED drivers require built-in safetyand protection features to maintain long-term device and system health. Devices such as the LM3643,LM3644, LM3648, LM3646, LM3642, LM36010, and LM36011 all provide many specific protection
Серия: LM36010 (1)
  • LM36010YKBR
  • Semiconductors > Power Management > LED Driver > Strobe & Flash LED Driver
На английском языке: Datasheet Texas Instruments LM36010YKBR
