Datasheet Texas Instruments MSP430FR2633IYQWT — Даташит
СерияMSP430FR2633
МодельMSP430FR2633IYQWT
MSP430 MCU с технологией CapTIvate — самый экономичный, наиболее помехоустойчивый емкостный сенсорный экран 24-DSBGA -40 до 85
MSP430FR263x, MSP430FR253x Capacitive Touch Sensing Mixed-Signal Microcontrollers datasheet
PDF, 2.8 Мб, Версия: B, Файл опубликован: 8 июн 2017
27 предложений от 10 поставщиков
IC MCU 16BIT 15.5KB FRAM 24DSBGA. MSP430 MSP430TM FRAM Microcontroller IC 16-Bit 16MHz 15.5KB (15.5K x 8) FRAM 24-DSBGA. Embedded...
MSP430FR2633IYQWT
338 ₽
MSP430FR2633IYQWT
339 ₽
MSP430FR2633IYQWT
от 516 ₽
Hi-Tech Circuit Group
MSP430FR2633IYQWT
Pin24
Package TypeYQW
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
Маркировка430FR2633
ADCADC10 - 8ch
AESN/A
Active Power126 uA/MHz
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset
BSLI2C,UART
CPUMSP430
FeaturedNA
Тактовая частота16 МГц
GPIO Pins19
I2C1
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory16 KB
Package GroupTSSOP,VQFN
Package Size: mm2:W x L32TSSOP: 89 mm2: 8.1 x 11(TSSOP),32VQFN: 25 mm2: 5 x 5(VQFN) PKG
RAM4 KB
SPI2
Special I/OCapTIvate Touch I/O
Standby Power1.5 LPM3-uA
Timers - 16-bit4
UART2
Wakeup Time10 us
  • Evaluation Modules & Boards: MSP-CAPT-FR2633
    MSP CapTIvate MCU Development Kit
  • Development Kits: CAPTIVATE-METAL
    Touch on Metal Capacitive Sensing Add-on Board for the CapTIvateВ™ Development Kit
    MSP EnergyTrace Technology
  • VLO Calibration on the MSP430FR4xx and MSP430FR2xx Family (Rev. A)
    PDF, 78 Кб, Версия: A, Файл опубликован: 19 фев 2016
    MSP430FR4xx and MSP430FR2xx (FR4xx/FR2xx) family microcontrollers (MCUs) provide various clock sources, including some high-speed high-accuracy clocks and some low-power low-system-cost clocks. Users can select the best balance of performance, power consumption, and system cost. The on-chip very low-frequency oscillator (VLO) is a clock source with 10-kHz typical frequency included in FR4xx/FR2xx
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR2633IYQWT
