Datasheet Texas Instruments MTDM8148CCYE2 — Даташит
СерияTMS320DM8148
МодельMTDM8148CCYE2
Цифровой медиапроцессор DaVinci 684-FCBGA
TMS320DM814x DaVinci Video Processors datasheet
PDF, 2.7 Мб, Версия: E, Файл опубликован: 13 дек 2013
Pin684
Package TypeCYE
Industry STD TermFCBGA
JEDEC CodeS-PBGA-N
Package QTY60
МаркировкаTMS320DM8148CCYE2
Width (мм)23
Length (мм)23
Thickness (мм)2.5
Pitch (мм).8
Max Height (мм)3.06
ARM CPU1 ARM Cortex-A8
ARM MHz1000 Max.
ApplicationsVideo Security,Thin Client,Video Conferencing,Video Phones
DRAMLPDDR,DDR2,DDR3
DSP1 C674x
DSP MHz750 Max.
EMAC10/100/1000
I2C4
On-Chip L2 Cache512 KB (ARM),256 KB (DSP)
Operating SystemsLinux,DSP/BIOS
PCI/PCIePCIe
Pin/Package684FCBGA
SPI4
UART6 SCI
USB2
Video Acceleration1 HDVICP
Video Port2 Output,2 Input,2 SD DACs,1 HDMI TX Configurable
Video Resolution/Frame Rate1080p,60 FPS or less
  • Evaluation Modules & Boards: TMDXEVM8148
    DM814x /AM387x Evaluation Module
    XDS200 USB Debug Probe
  • TMS320DM814x/AM387x Power Estimation Spreadsheet (Rev. A)
    PDF, 18 Кб, Версия: A, Файл опубликован: 10 сен 2012
    This article describes how to model power consumption for a user's application and to present some measured power scenarios for the TMS320DM814x DaVinciв„ў digital media processors and AM387x Sitaraв„ў ARMВ® microprocessors (MPUs) PG2.x and PG3.x samples using a provided power estimation spreadsheet.This article has been contributed to the TI Developer Wiki. To see the most recen
  • TI814x-DDR3-Init-U-Boot
    PDF, 37 Кб, Файл опубликован: 31 окт 2011
    This article describes how to initialize the DDR3 and uBoot on the TMS320DM814x DaVinciв„ў digital media processors (DSP) and AM387x ARMВ® microprocessors (MPUs) PG2.x samples using the software leveling process.This article has been contributed to the TI Embedded Processors Wiki. To see the most recently updated version or to contribute, visit this topic at:
  • Error Detection and Correction Mechanism of TMS320C64x+/C674x (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 19 июл 2013
    This application report describes the error detection and correction mechanism of the C64x+/C674x megamodule L1P and L2 memories implemented on some devices. Depending on the type of application, these mechanisms are used to either provide diagnostic measures to detect faults in the memory that could lead to unacceptable risk for the user or to increase the availability of the system.
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments MTDM8148CCYE2
