Datasheet Texas Instruments OPA180QDGKRQ1 — Даташит
Серия | OPA180-Q1 |
Модель | OPA180QDGKRQ1 |
Automotive-Qualified 0.1ОјV/В°C Drift, Low-Noise, RRO, 36V, Zero-Drift Op Amp 8-VSSOP -40 to 125
OPAx180-Q1 0.1-ОјV/В°C Drift, Low-Noise, Rail-to-Rail Output, 36-V, Zero-Drift Operational Amplifiers datasheet
PDF, 1.2 Мб, Файл опубликован: 5 июн 2017
![]() 17 предложений от 11 поставщиков IC OPAMP ZERO-DRIFT 1CIRC 8VSSOP. Zero-Drift Amplifier 1 Circuit Rail-to-Rail 8-VSSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps | |||
OPA180QDGKRQ1 Texas Instruments | 72 ₽ | ||
OPA180QDGKRQ1 Texas Instruments | 259 ₽ | ||
OPA180QDGKRQ1 Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 180 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Additional Features | EMI Hardened,Zero Drift |
Архитектура | CMOS |
CMRR(Min) | 104 дБ |
CMRR(Typ) | 114 дБ |
GBW(Typ) | 2 МГц |
Input Bias Current(Max) | 1000 pA |
Iq per channel(Max) | 0.525 мА |
Iq per channel(Typ) | 0.45 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 0.1 uV/C |
Output Current(Typ) | 18 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Automotive |
Slew Rate(Typ) | 0.8 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 10 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.075 мВ |
- Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA180-Q1 (1)
- OPA180QDGKRQ1
