Datasheet Texas Instruments OPA3684IDG4 — Даташит
СерияOPA3684
МодельOPA3684IDG4
Маломощный операционный усилитель с тройной обратной связью по току и отключением 14-SOIC от -40 до 85
Low-Power, Triple Current Feedback Operational Amplifier with Disable datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 2 июл 2008
Pin14
Package TypeD
Package QTY50
МаркировкаOPA3684
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic67 dBc
3rd Harmonic70 dBc
@ MHz5
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураBipolar,Current FB
BW @ Acl210 МГц
CMRR(Min)53 дБ
CMRR(Typ)60 дБ
GBW(Typ)210 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)1.8 мА
Iq per channel(Typ)1.7 мА
Количество каналов3
Offset Drift(Typ)12 uV/C
Output Current(Typ)120 мА
Rail-to-RailNo
Slew Rate(Typ)820 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)3.7 нВ/rtГц
Vn at Flatband(Typ)3.7 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3.5 мВ
  • Evaluation Modules & Boards: DEM-OPA368XDBQ
    OPA368x Evaluation Fixture
    DEM-OPA368xD: Demonstration board
  • Evaluation Modules & Boards: DEM-OPA-SO-3B
    DEM-OPA-SO-3B
  • Evaluation Modules & Boards: DEM-OPA-SSOP-3B
    DEM-OPA-SSOP-3B
  • Current Feedback Amplifiers: Review, Stability Analysis, and Applications
    PDF, 53 Кб, Файл опубликован: 20 ноя 2000
    The majority of op amp circuits are closed-loop feedback systems that implement classical control theory analysis. Analog designers are comfortable with Voltage FeedBack (VFB) op amps in a closed-loop system and are familiar with the ideal op amp approximations feedback permit. This application bulletin will demonstrate how CFB op amps can be analyzed in a similar fashion. Once the closed-loop sim
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA3684IDG4
