Datasheet Texas Instruments PGA460TPWR — Даташит
Серия | PGA460 |
Модель | PGA460TPWR |
Ультразвуковой сигнальный процессор и драйвер преобразователя 16-TSSOP -40 до 105
PGA460 Ultrasonic Signal Processor and Transducer Driver datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 25 авг 2017
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | PGA460 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Active Supply Current(Typ) | 12 мА |
Interface | UART / USART, TCI (Time Command Interface), OWU (One-Wire UART) |
Рабочий диапазон температур | от -40 до 105 C |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rating | Catalog |
Sleep Supply Current(Typ) | 300 uA |
Special Features | Fully integrated |
Напряжение питания | 28 Min |
- Evaluation Modules & Boards: BOOSTXL-PGA460
PGA460-Q1 Ultrasonic Sensor Signal Conditioning EVM With Transducers
- PGA460 Frequently Asked Questions (FAQ) and EVM Troubleshooting GuidePDF, 2.0 Мб, Файл опубликован: 1 май 2017
This document is intended to answer the most common and frequently asked questions (FAQs) that users have when evaluating the PGA460 or PGA460-Q1 EVM and GUI. Step-by-step procedures to hardware troubleshooting and software debugging are provided. Recommendations to improve performance and best practices to prevent device failure, GUI errors, or improper measurement techniques are also discussed. - PGA460 Software Development Guide (Rev. A)PDF, 269 Кб, Версия: A, Файл опубликован: 22 авг 2017
The objective of this guide is to explain the high-level software flow for platform development with the PGA460 device using UART, Time Command Interface (TCI), and/or One-Wire UART (OWU) communication.This report contains a software development flow-chart, one-time mass-production initializationrequirements, main executable routines, and source code examples. The example softw - PGA460 Ultrasonic Module Hardware and Software OptimizationPDF, 340 Кб, Файл опубликован: 17 фев 2017
This document introduces all of the necessary design and environmental considerations when developing and optimizing an ultrasonic sensor module using the PGA460. Ultrasonic modules behave differently across various temperatures, transmission mediums, targets, and transducers types. Building the module, therefore, requires an understanding of the different ultrasonic components available for pairi
Серия: PGA460 (2)
- PGA460TPW PGA460TPWR
- Semiconductors > Sensing Products > Ultrasonic Sensing
