Datasheet Texas Instruments SN74SSTVF16859S8G3 — Даташит
СерияSN74SSTVF16859
МодельSN74SSTVF16859S8G3
Регистровый буфер от 13 до 26 бит с входами и выходами SSTL_2 56-VQFN от 0 до 70
SN74SSTVF16859 datasheet
PDF, 891 Кб, Версия: B, Файл опубликован: 30 янв 2004
Pin56
Package TypeRGQ
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
Package QTY2000
МаркировкаSSF859
Width (мм)8
Length (мм)8
Thickness (мм).93
Pitch (мм).5
Max Height (мм)1
Absolute Jitter (Peak-to-Peak Cycle or Period Jitter)N/A ps
FunctionDDR Register
Количество выходов26
Operating Frequency Range(Max)500 МГц
Output Drive16 мА
Package GroupVQFN
Package Size: mm2:W x L56VQFN: 64 mm2: 8 x 8(VQFN) PKG
VCC2.5 В
t(phase error)N/A ps
tsk(o)N/A ps
  • 56-Pin Quad Flatpack No-Lead Logic Package
    PDF, 275 Кб, Файл опубликован: 7 фев 2003
    Texas Instruments (TI) Quad Flatpack No-Lead (QFN) 56-terminal package complies with JEDEC standard MO-220, allows for board miniaturization, and holds several advantages over traditional SOIC, TQFP, TSSOP, and TVSOP packaging. This package, designated RGQ by TI, physically is smaller than traditional leaded solutions, has a smaller routing area, improved thermal performance, and improved electric
  • Application of the SN74SSTV32852 in Stacked, Low-Profile (1U) PC-1600/2100 DIMMs
    PDF, 445 Кб, Файл опубликован: 7 ноя 2001
    Many memory-module manufacturers are turning to low-profile (1U) DIMM designs that significantly increase memory density in computer workstations and servers. The reduction in DIMM height consequently affects the design and layout of the boards. The stacked 1U DIMMs present a unique and challenging problem due partly to the reduction in area for mounting components and also due to the load. The TI
  • Application of the SN74SSTVF16857 in Planar PC2700 (DDR-333) RDIMMs
    PDF, 359 Кб, Файл опубликован: 10 янв 2003
    The high-capacity memory modules used in servers and workstations present a complex load to the memory controller used in these high-reliability, high-performance systems. To meet the demands of stable functionality over a broad spectrum of operating environments and system timing needs, and to support data integrity, these dual in-line memory modules (DIMMs) require the use of registers in the ad
  • Low-Power Support Using Texas Instruments SN74SSTV16857 and SN74SSTV16859
    PDF, 138 Кб, Файл опубликован: 9 фев 2001
    The Texas Instruments SN74SSTV16857 and SN74SSTV16859 registers support the low-power mode of the DDR-DIMM. This application report explains the low-power mode and the features of the registers that support the low-power mode. Also, the considerations that the system designer must be aware of when implementing the low-power state of a registered memory module are explained. The sequence that must
  • Semiconductors > Clock and Timing > Memory Interface Clocks and Registers
На английском языке: Datasheet Texas Instruments SN74SSTVF16859S8G3
