Datasheet Texas Instruments THVD1550DGK — Даташит
СерияTHVD1550
МодельTHVD1550DGK
5V RS-485 Transceivers With В±18kV IEC ESD Protection 8-VSSOP -40 to 125
THVD15xx 5-V RS-485 Transceivers With В±18-kV IEC ESD Protection datasheet
PDF, 1.4 Мб, Файл опубликован: 12 сен 2017
24 предложений от 14 поставщиков
IC TRANSCEIVER HALF 1/1 8VSSOP. 1/1 Transceiver Half RS485 8-VSSOP. Interface - Drivers, Receivers, Transceivers
THVD1550DGK
от 38 ₽
Рутоника
THVD1550DGK
92 ₽
THVD1550DGK .
от 366 ₽
THVD1550DGK
от 386 ₽
Package TypeDGK
Industry STD TermVSSOP
Package QTY280
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Common Mode Range-15 to 15
DuplexHalf
Fail Safeidle,open,short
Fault Protection-18 to 18 В
HBM ESD30 kV
ICC(Max)1 мА
IEC 61000-4-2 Contact18 +/- kV
No. of RX1
No. of TX1
Number of Nodes256
Package GroupVSSOP
Signaling Rate(Max)50 Mbps
Supply Voltage(s)(Nom)5 В
RoHSSee ti.com
  • Signal Integrity vs. Transmission Rate and Cable Length for RS-485 Transceivers
    PDF, 1.3 Мб, Файл опубликован: 29 авг 2017
    This application note contains lab data on the signal integrity of the THVD1550 RS-485 transceiver device at various cable lengths and data rates. Jitter measurements were gathered with the results tabulated and plotted.
Серия: THVD1550 (4)
На английском языке: Datasheet Texas Instruments THVD1550DGK
