Datasheet Texas Instruments TMP116NAIDRVR — Даташит
СерияTMP116
МодельTMP116NAIDRVR
Цифровой датчик температуры с точностью ±0,2°C и энергонезависимой памятью 6-WSON от -55 до 125
TMP116 High-Accuracy, Low-Power, Digital Temperature Sensor With SMBus- and I2C-Compatible Interface datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 20 май 2019
Pin6
Package TypeDRV
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
Маркировка116N
Width (мм)2
Length (мм)2
Thickness (мм)0.75
Pitch (мм)0.65
Max Height (мм)0.8
Addresses4
Approx. price0.79 | 1ku US$
Device typeLocal
Основные особенностиALERT,One-shot conversion,EEPROM,NIST traceable
InterfaceI2C, SMBus, 2-Wire
Local sensor accuracy(Max)0.2 +/- C
Operating temperature range-55 to 125 C
Package GroupWSON|6
Package size: mm2:W x L6WSON: 4 mm2: 2 x 2 (WSON|6) PKG
Supply current(Max)4.5 uA
Supply current(Typ)3.5 uA
Supply voltage(Max)5.5 В
Supply voltage(Min)1.9 В
Temp resolution(Max)16 bits
  • Evaluation boards: TMP116METER-EVM
    Low Power Temperature Digital Meter
  • Evaluation boards: BOOSTXL-BASSENSORS
    Building Automation Sensors BoosterPack Module
  • Evaluation boards: TMP116EVM
    TMP116 High-Precision Digital Temperature Sensor Evaluation Module
  • Precise Temperature Measurements With the TMP116 and TMP117 (Rev. A)
    PDF, 917 Кб, Версия: A, Файл опубликован: 9 авг 2018
    Engineers must carefully consider the overall system design when designing high-precision temperature measurement applications. This application note provides recommendations on how to design a precise temperature measuring system based on the TMP116 and TMP117 temperature sensors. By following this application note the user should be able to design a precise measuring system which adheres to the
  • RTD Replacement in Heat Meter & Cold Junction Compensation Systems (Rev. B)
    PDF, 176 Кб, Версия: B, Файл опубликован: 18 окт 2018
  • Design Challenges of Wearable Temperature Sensing
    PDF, 340 Кб, Файл опубликован: 14 сен 2018
  • Layout Considerations for Wearable Temperature Sensing
    PDF, 335 Кб, Файл опубликован: 26 июл 2018
  • Design Considerations for Measuring Ambient Air Temperature (Rev. B)
    PDF, 1.4 Мб, Версия: B, Файл опубликован: 10 сен 2018
    Power-hungryelectroniccomponentssuchas processorchipsfield programmablegatearrays(FPGAs)application-specificintegratedcircuits(ASICs)as well as powerICs heatup duringoperation.Whenthesystemis turnedon the heatgeneratedby theseICs transfersto lowertemperatureobjectsnearby.Measuringambientair temperaturewith a surfacemountdevi
  • Replacing Resistance Temperature Detectors with the TMP116 Temp Sensor
    PDF, 133 Кб, Файл опубликован: 6 ноя 2017
  • Ambient Temperature Measurement Layout Considerations
    PDF, 893 Кб, Файл опубликован: 16 июл 2018
  • How to monitor board temperature
    PDF, 1.6 Мб, Файл опубликован: 28 янв 2019
  • Temperature sensing fundamentals
    PDF, 64 Кб, Файл опубликован: 28 янв 2019
  • Wearable Temp-Sensing Layout Considerations Optimized for Thermal Response (Rev. B)
    PDF, 3.6 Мб, Версия: B, Файл опубликован: 23 окт 2018
    This applicationnotediscussesthermalresponseconsiderationsfor IC temperaturesensorsin measuringskin temperaturefor wearableapplicationssuchas fitnessbandsand medicaldevices.It will specificallyfocuson twodevices—the LMT70andthe TMP117temperaturesensors—overthe humanbodytemperaturerange.Thisinformationcan be appliedhoweverto ot
  • Calculating Useful Lifetimes of Temperature Sensors
    PDF, 522 Кб, Файл опубликован: 6 июл 2018
  • High-Performance Processor Die Temperature Monitoring (Rev. A)
    PDF, 357 Кб, Версия: A, Файл опубликован: 17 окт 2019
  • Low-Power Design Techniques for Temperature-Sensing Applications
    PDF, 235 Кб, Файл опубликован: 6 июн 2019
    Power consumption is a critical design consideration for many sensor applications. Battery-powered devices such as smartphones and laptops need thermal monitoring to effectively blend performance with battery life. Logging devices designed for cold chain tracking must have a long enough battery life to perform their mission. IoT-sensing devices can be made smaller cheaper and simpler to deploy
  • Temperature sensors: PCB guidelines for surface mount devices (Rev. A)
    PDF, 5.6 Мб, Версия: A, Файл опубликован: 18 янв 2019
    Power hungry electronic components such as CPUs GPUs or FPGAs as well as voltage regulators heat up during operation. Some applications require ambient air temperature measurements while others need to measure the temperature of a nearby component on the PCB. Measuring ambient air temperature with a surface mount technology (SMT) device is challenging due to the thermal influence of other compo
Серия: TMP116 (4)
  • Semiconductors > Analog and Mixed-Signal > Sensors > Temperature sensors > Digital temperature sensors
На английском языке: Datasheet Texas Instruments TMP116NAIDRVR
