Datasheet Texas Instruments TNETV2665VIDZWT4 — Даташит
СерияTMS320C6424
МодельTNETV2665VIDZWT4
Процессор цифровых сигналов с фиксированной точкой 361-NFBGA от 0 до 90
TMS320C6424 Fixed-Point Digital Signal Processor datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 11 янв 2010
Pin361361361361
Package TypeZWTZWTZWTZWT
Industry STD TermNFBGANFBGANFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY90909090
МаркировкаTMS3204L2C6424ZWT
Width (мм)16161616
Length (мм)16161616
Thickness (мм).9.9.9.9
Pitch (мм).8.8.8.8
Max Height (мм)1.41.41.41.4
DSP1 C64x+
    XDS200 USB Debug Probe
  • Implementing DDR2 PCB Layout on the TMS320C6424 DSP
    PDF, 147 Кб, Файл опубликован: 16 окт 2008
    This application report contains implementation instructions for the DDR2 interface contained on the TMS320C6424 digital signal processor (DSP) device. The approach to specifying interface timing for the DDR2 interface is quite different than on previous devices.The previous approach specified device timing in terms of data sheet specifications and simulation models. The system designer was r
  • TMS320C642x Power Consumption Summary (Rev. D)
    PDF, 141 Кб, Версия: D, Файл опубликован: 17 фев 2012
  • TMS320C642x Pin Multiplexing Utility
    PDF, 1.3 Мб, Файл опубликован: 9 июл 2007
    The C642x devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. The software accompanying this application report allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices of the C642x family support the peripherals that are select
  • Using the TMS320C642x Bootloader (Rev. B)
    PDF, 256 Кб, Версия: B, Файл опубликован: 23 мар 2012
    This document describes the functionality of the C642x ROM bootloader software. Please note that the ROM bootloader requires use of Application Image Script (AIS) as the primary data format for loading code/data. AIS is a Texas Instruments, Inc. proprietary data format. AIS is explained in detail in Section 2 of this document.
  • Using DMA with Framework Components for C64x+ (Rev. A)
    PDF, 859 Кб, Версия: A, Файл опубликован: 29 окт 2007
    This application note describes the standard DMA software abstractions and interfaces for TMS320 DSP Algorithm Standard (xDAIS) compliant algorithms designed for the C64x+ EDMA3 controller using DMA Framework Components utilities. The DMA Framework Component utilities described in this document include a standard DMA resource specification and negotiation protocol (IDMA3), a DMA Resource Manager (
  • 5Vin C642x Power using a PMIC (Multi-output DC/DC Converter)
    PDF, 302 Кб, Файл опубликован: 9 окт 2008
  • TMS320C620x/C642x McBSP: UART (Rev. C)
    PDF, 293 Кб, Версия: C, Файл опубликован: 9 сен 2008
    This document describes how to use the multichannel buffered serial port (McBSP) in the Texas Instruments (TI) TMS320C6000в„ў (C6000в„ў) digital signal processors (DSP) to interface to a universal asynchronous receiver/transmitter (UART). Descriptions of the hardware configuration and software routines necessary for proper functionality are included.The McBSP is not capable of support
  • 5Vin C642x Power using DC/DC Controllers and LDO
    PDF, 741 Кб, Файл опубликован: 9 окт 2008
  • 5Vin C642x Power using Integrated-FET DC/DC Converters and LDO
    PDF, 550 Кб, Файл опубликован: 9 окт 2008
  • 12Vin C642x Power using Integrated-FET DC/DC Converters and LDO
    PDF, 310 Кб, Файл опубликован: 9 окт 2008
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • TMS320C64x to TMS320C64x+ CPU Migration Guide (Rev. A)
    PDF, 310 Кб, Версия: A, Файл опубликован: 20 окт 2005
    This document describes migration from the Texas Instruments TMS320C64xв„ў digital signal processor (DSP) to the TMS320C64x+в„ў DSP. The objective of this document is to indicate differences between the two cores and to briefly describe new features. Functionality in the devices that is identical is not included. For detailed information about either device, see the TMS320C64x/C64x+ DSP
  • Plastic Ball Grid Array [PBGA] Application Note (Rev. B)
    PDF, 1.6 Мб, Версия: B, Файл опубликован: 13 авг 2015
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • Thermal Considerations for the DM64xx, DM64x, and C6000 Devices
    PDF, 127 Кб, Файл опубликован: 20 май 2007
    As integrated circuit (IC) components become more complex, the challenge of producing an end product with superior thermal performance increases. Thermal performance is a system level concern, impacted by IC packaging as well as by printed circuit board (PCB) design. This application report addresses the thermal considerations for the TMS320DM64xx, TMS320DM64x, and TMS320C6000в„ў DSP devices.
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP > Other C6000 DSP
На английском языке: Datasheet Texas Instruments TNETV2665VIDZWT4
