Datasheet Texas Instruments TNETV2685FIDZUT9 — Даташит
СерияTMS320DM648
МодельTNETV2685FIDZUT9
Цифровой медиапроцессор 529-FCBGA от 0 до 90
TMS320DM647/TMS320DM648 Digital Media Processors datasheet
PDF, 1.4 Мб, Версия: H, Файл опубликован: 10 апр 2012
Pin529529529
Package TypeZUTZUTZUT
Industry STD TermFCBGAFCBGAFCBGA
JEDEC CodeS-PBGA-NS-PBGA-NS-PBGA-N
Package QTY848484
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320DM648ZUT@2007 TI900MHZ
Width (мм)191919
Length (мм)191919
Thickness (мм)2.652.652.65
Pitch (мм).8.8.8
Max Height (мм)3.33.33.3
ApplicationsAutomotive,Industrial,Video and Imaging
DRAMDDR2
DSP1 C64x
DSP MHz720,800,900,1100 Max.
I2C1
On-Chip L2 Cache512 KB(DSP)
Operating SystemsDSP/BIOS,VLX
Рабочий диапазон температурот 0 до 90 C
PCI/PCIe1 32-Bit [66 MHz]
Pin/Package529FCBGA
Video Acceleration1 VICP
Video Port5 16-Bit Dual-Ch Configurable
Video Resolution/Frame RateD1 or Less
  • Development Kits: TMDSDVP648
    DM648 Digital Video Development Platform
    Статус продукта: NRND (Не рекомендуется для новых разработок)
  • JTAG Emulators/ Analyzers: XDS560TRACE
    XDS560 Trace Emulator
    XDS200 USB Debug Probe
  • TMS320DM648/7 SoC Architecture and Throughput Overview
    PDF, 1.8 Мб, Файл опубликован: 12 июн 2009
    This application report provides information on the DM648/7 throughput performance and describes the DM648/7 System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput performance of different peripherals on th
  • Using the TMS320DM647/DM648 Bootloader (Rev. D)
    PDF, 316 Кб, Версия: D, Файл опубликован: 1 июн 2009
    This document describes the functionality of the TMS320DM647/DM648 ROM bootloader software. The ROM bootloader resides in the ROM of the device beginning at ROM address 0x00100000. The ROM boot loader (RBL) implements methods for booting in the listed modes. It reads the contents of the BOOTCFG register to determine boot mode and performs appropriate commands to effect boot of device. If an improp
  • TMS320DM647/8 Power Consumption Summary (Rev. B)
    PDF, 131 Кб, Версия: B, Файл опубликован: 6 янв 2010
    NOTE: PRELIMINARY DATA FOR TMX DEVICES. INFORMATION SUBJECT TO CHANGEThis application report discusses power consumption of the Texas Instruments TMS320DM647/8 Digital Signal Processor (DSP). Power consumption is highly application-dependent, so a spreadsheet is provided to model power consumption for your applications.
  • Software Migration From TMS320DM642 to TMS320DM648/DM6437
    PDF, 178 Кб, Файл опубликован: 19 авг 2008
  • Migrating from TMS320DM642/3/1/0 to the TMS320DM647/DM648 Device
    PDF, 79 Кб, Файл опубликован: 7 июн 2007
    This application report describes issues of interest related to migration from the TMS320DM642/3/1/0 to the TMS320DM648/7 device. The objective of this document is to indicate differences between the two device portfolios. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, see the TMS320DM642, TMS320DM643, or
  • Running a TMS320C64x+ Codec Across TMS320C64x+ Based DSP Platforms
    PDF, 969 Кб, Файл опубликован: 24 сен 2009
    This application report describes the device differences to be taken care for running the C64x+™ video codec software on different C64x+ based platforms. This document assumes that the codec software is developed for the C64x+ digital signal processor (DSP) core. As many TI platforms have a C64x+ DSP this document gives the details for running the standalone codec software on a C64x+ platfo
  • EDMA v2.0 to EDMA v3.0 (EDMA3) Migration Guide (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 21 авг 2008
    This application report summarizes the key differences between the enhanced direct memory access (EDMA3) used on C64x+в„ў DSP devices and the EDMA2 used on TMS320C64xв„ў DSP devices, and provides guidance for migrating from EDMA2 to EDMA3.
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • Thermal Considerations for the DM64xx, DM64x, and C6000 Devices
    PDF, 127 Кб, Файл опубликован: 20 май 2007
    As integrated circuit (IC) components become more complex, the challenge of producing an end product with superior thermal performance increases. Thermal performance is a system level concern, impacted by IC packaging as well as by printed circuit board (PCB) design. This application report addresses the thermal considerations for the TMS320DM64xx, TMS320DM64x, and TMS320C6000в„ў DSP devices.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TNETV2685FIDZUT9
