Datasheet Texas Instruments TPD4E05U06DQAR — Даташит
СерияTPD4E05U06
МодельTPD4E05U06DQAR
4-канальный диод IEC со сверхнизкой емкостью для защиты от электростатического разряда 10-USON от -40 до 125
TPDxE05U06 1, 4, 6 Channel ESD Protection Device for Super-Speed (Up to 6 Gbps) Interface datasheet
PDF, 1.6 Мб, Версия: L, Файл опубликован: 7 ноя 2016
Pin1010
Package TypeDQADQA
Industry STD TermUSONUSON
JEDEC CodeR-PSSO-NR-PSSO-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаBRBRY
Width (мм)11
Length (мм)2.52.5
Thickness (мм).5.5
Pitch (мм).5.5
Max Height (мм).55.55
Bi-/Uni-DirectionalUni-Directional
Breakdown Voltage(Min)6.5 В
Clamping Voltage10 В
Dynamic Resistance(Typ)0.8 Ω
IEC 61000-4-2 Air-Gap15 +/- kV
IEC 61000-4-2 Contact12 +/- kV
IO Capacitance(Typ)0.5 пФ
IO Leakage Current(Max)10 нА
InterfaceEthernet,HDMI 1.4/1.3,HDMI 2.0,LVDS,SATA/PCIe,USB 3.0,USB Type-C
Количество каналов4
Package GroupUSON
Package Size: mm2:W x L10USON: 3 mm2: 1 x 2.5(USON) PKG
Special FeaturesN/A
  • Evaluation Modules & Boards: TPD4E05U06DQAEVM
    TPD4E05U06 4-Channel Ultra-Low-Capacitance IEC ESD Protection Diode Evaluation Module
  • Evaluation Modules & Boards: TUSB1042EVM
    TUSB1042 10Gbps USB3.1G2 2:1 Linear Redriver Switch Evaluation Module
  • Evaluation Modules & Boards: TPS65982-EVM
    TPS65982 USB Type-C & USB PD Controller Power Switch & High Speed Multiplexer EVM
  • Evaluation Modules & Boards: TPS65983EVM
    TPS65983 USB Type-C and USB PD Controller Power Switch and High-Speed Multiplexer Evaluation Module
  • Evaluation Modules & Boards: TUSB322EVM
    TUSB322 USB Type-C Configuration Channel Logic and Port Control With VCONN Evaluation Module
  • Evaluation Modules & Boards: TUSB320-HA-EVM
    TUSB320HAI USB Type-C Configuration Channel Logic and Port Control Evaluation Module
  • Evaluation Modules & Boards: TUSB320-LA-EVM
    TUSB320LAI USB Type-C Configuration Channel Logic and Port Control Evaluation Module
  • Evaluation Modules & Boards: TUSB320EVM
    TUSB320 Evaluation Module (EVM)
  • Evaluation Modules & Boards: 3220UFP-DGLEVM
    HD3SS3220 Type-C Up Facing Port Controller With SuperSpeed 2:1 MUX Evaluation Module
  • Evaluation Modules & Boards: 3220DFP-DGLEVM
    HD3SS3220 Type-C Down Facing Port Controller With SuperSpeed 2:1 MUX Evaluation Module
  • Evaluation Modules & Boards: TUSB546EVM
    TUSB546 USB Type-CВ™ Alternate Mode Redriver Switch EVM
  • Evaluation Modules & Boards: TUSB1046EVM
    TUSB1046 USB Type-CВ™ Alternate Mode Redriver Switch EVM
  • Evaluation Modules & Boards: TPS65986EVM
    TPS65986 USB Type-C & USB PD Controller & Power Switch Evaluation Module
  • Evaluation Modules & Boards: EM1402EVM
    16-Channel Active Cell Balance Evaluation Module
  • Evaluation Modules & Boards: TMDXICE110
    AMIC110 Industrial Communications Engine (ICE)
    Статус продукта: Анонсирован (Компонент анонсирован, но еще не запущен в серийное производство. Образцы могут быть как доступны, так и нет)
  • Evaluation Modules & Boards: K2GICE
    66AK2Gx (K2G) Industrial Communications Engine (ICE)
  • Evaluation Modules & Boards: USB-CTM-MINIDK-EVM
    USB Type-Cв„ў Minidock Board With Video and Charging Support Evaluation Module
  • Picking ESD Diodes for Ultra High-Speed Data Lines
    PDF, 103 Кб, Файл опубликован: 29 июн 2016
  • Reading and Understanding an ESD Protection Datasheet
    PDF, 2.5 Мб, Файл опубликован: 19 май 2010
    System engineers must choose all components for their designs carefully. Picking the right ESD protectionelements can be challenging as the matter of protecting devices on the PCB against ESD stress hasbecome an increasingly complex task.Texas Instruments offers a wide range of ESD protection elements. Understanding the datasheetparameters of ESD protection elements is paramount
  • Design Considerations for System-Level ESD Circuit Protection
    PDF, 381 Кб, Файл опубликован: 25 сен 2012
  • ESD Layout Guide
    PDF, 638 Кб, Файл опубликован: 4 мар 2015
Серия: TPD4E05U06 (1)
  • TPD4E05U06DQAR
  • Semiconductors > Interface > Circuit Protection > ESD Protection and TVS Surge Diodes
На английском языке: Datasheet Texas Instruments TPD4E05U06DQAR
