Datasheet Texas Instruments TPD4S014DSQR — Даташит
СерияTPD4S014
МодельTPD4S014DSQR
Полное устройство защиты USB-порта 10-WSON -40 to 85
TPD4S014 USB Charger Port Protection Including ESD Protection for All Lines and Overvoltage Protection on VBUS datasheet
PDF, 3.2 Мб, Версия: G, Файл опубликован: 31 дек 2015
Pin10
Package TypeDSQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаZTE
Width (мм)2
Length (мм)2
Thickness (мм).75
Pitch (мм).4
Max Height (мм).8
Bi-/Uni-DirectionalUni-Directional
Breakdown Voltage(Min)6 В
Clamping Voltage15 В
Dynamic Resistance(Typ)1 Ω
IEC 61000-4-2 Air-Gap15 +/- kV
IEC 61000-4-2 Contact15 +/- kV
IO Capacitance(Typ)1.5 пФ
IO Leakage Current(Max)1000 нА
InterfaceUSB 2.0
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Special FeaturesOver Voltage Protection
  • Evaluation Modules & Boards: TPD4S014EVM
    TPD4S014EVM: Complete Protection Solution for USB Charger Port Including ESD Protection
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Reading and Understanding an ESD Protection Datasheet
    PDF, 2.5 Мб, Файл опубликован: 19 май 2010
    System engineers must choose all components for their designs carefully. Picking the right ESD protectionelements can be challenging as the matter of protecting devices on the PCB against ESD stress hasbecome an increasingly complex task.Texas Instruments offers a wide range of ESD protection elements. Understanding the datasheetparameters of ESD protection elements is paramount
  • Design Considerations for System-Level ESD Circuit Protection
    PDF, 381 Кб, Файл опубликован: 25 сен 2012
  • ESD Layout Guide
    PDF, 638 Кб, Файл опубликован: 4 мар 2015
Серия: TPD4S014 (1)
  • TPD4S014DSQR
  • Semiconductors > Interface > Circuit Protection > Application-Specific Port Protection
На английском языке: Datasheet Texas Instruments TPD4S014DSQR
