Datasheet Texas Instruments TPIC2603DWRG4 — Даташит
Серия | TPIC2603 |
Модель | TPIC2603DWRG4 |
6-Channel Serial Interface Low-Side Driver 24-SOIC
6-Channel Serial Interface Low-Side Driver datasheet
PDF, 802 Кб, Версия: A, Файл опубликован: 1 мар 1996
Купить TPIC2603DWRG4 на РадиоЛоцман.Цены — от 170 до 860 ₽ 16 предложений от 12 поставщиков Микросхема: IC PWR DRIVER 1:6 24SOIC | |||
TPIC2603DWRG4 Texas Instruments | 170 ₽ | ||
TPIC2603DWRG4 Texas Instruments | 227 ₽ | ||
TPIC2603DWRG4 Texas Instruments | 555 ₽ | ||
TPIC2603DWRG4 Texas Instruments | по запросу |
Pin | 24 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TPIC2603 |
Width (мм) | 7.5 |
Length (мм) | 15.4 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Ibat(Typ) | 5 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG |
Special Features | Diagnostics,Fault Protection,Integrated Power Controller |
VGATE | - В |
Vbat | 5.5 - 25 В |
fSCLK | 4 МГц |
- Linear Products Automotive Solenoid and Lamp ControlPDF, 92 Кб, Файл опубликован: 1 мар 1996
A typical automotive engine control unit (ECU) has inputs such as a coolant temperature sensor and a manifold absolute pressure (MAP) sensor. The ECU outputs control various loads which include solenoids, valves, lamps, relays, and ignition. The TPIC2603 can be used to switch the ECU control outputs. In addition, it is well-suited to switch other loads such as door chimes, interior lighting, fuel
Серия: TPIC2603 (4)
- TPIC2603DW TPIC2603DWG4 TPIC2603DWR TPIC2603DWRG4
- Semiconductors > Power Management > Power Management Special Functions > Interface Controlled Pre-FET Drivers
