Datasheet Texas Instruments TPIC6595DWR — Даташит
| Серия | TPIC6595 |
| Модель | TPIC6595DWR |
8-битный сдвиговый регистр 20-SOIC от -40 до 125
Power Logic 8-Bit Shift Register datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 18 май 2005
Купить TPIC6595DWR на РадиоЛоцман.Цены — от 41 до 5 696 ₽44 предложений от 19 поставщиков Микросхема Регистр сдвига, TEXAS INSTRUMENTS TPIC6595DWR Shift Register, Serial to Parallel, 1Element, 8Bit, SOIC, 20Pins | |||
| TPIC6595DWR Texas Instruments | 100 ₽ | ||
| TPIC6595DWR Texas Instruments | 111 ₽ | ||
| TPIC6595DWR Texas Instruments | 5 696 ₽ | ||
| TPIC6595DWR Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | TPIC6595 |
| Width (мм) | 7.5 |
| Length (мм) | 12.8 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| EAS | 75 mJ |
| ICC | 15 uA |
| IO(CONT) | 0.25 A |
| IO(PEAK) | 0.75 A |
| Package Group | SOIC |
| Package Size: mm2:W x L | 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG |
| VDS(Max) | 45 В |
| rDS(on) | 1.3 Ohms |
| tPLH | 650 нс |
- TPIC6595 Power+ Logic(TM) 8-Bit Shift Reg. With Low-Side Power DMOS Switches (Rev. A)PDF, 190 Кб, Версия: A, Файл опубликован: 1 июл 1993
The TPIC6595 is a monolithic device that contains eight 1.5A/45-V low-side DMOS power switches combined with the logic functions of an SN74HC595, and packaged in a 20-pin dual in-line plastic package (DIP) or wide body surface-mount package (DW). The TPIC6595?s outputs are inverted relative to those of the SN74HC595. This document provides a functional description of the TPIC6595 and detailed app
Серия: TPIC6595 (5)
- TPIC6595DW TPIC6595DWG4 TPIC6595DWR TPIC6595DWRG4 TPIC6595N
- Semiconductors > Logic > Power Logic
