Datasheet Texas Instruments OPA111SM — Даташит
СерияOPA111
МодельOPA111SM
Малошумящий прецизионный операционный усилитель Difet 8-TO-99
Low Noise Precision Difet® Operational Amplifier datasheet
PDF, 150 Кб, Файл опубликован: 27 сен 2000
Package TypeLMC
Industry STD TermTO-CAN
JEDEC CodeO-MBCY-W
Width (мм)9.08
Length (мм)9.08
Thickness (мм)4.4
Pitch (мм)2.54
Max Height (мм)5.72
Рекомендуемая замена
ReplacementOPA111BM
Replacement CodeF
RoHSНе совместим
  • Noise Analysis of FET Transimpedance Amplifiers
    PDF, 97 Кб, Файл опубликован: 2 окт 2000
    The availability of detailed noise spectral density characteristics for the OPA111 amplifier allows an accurate noise error analysis in a variety of different circuit configurations. The fact that the spectral characteristics are guaranteed maximums allows absolute noise errors to be truly bounded.
  • Feedback Circuit Clamps Precisely
    PDF, 26 Кб, Файл опубликован: 27 сен 2000
    A limiter circuit consisting of an input buffer (A1), an output-scaling amplifier (A2), two zener diodes (Z1 and Z2), and several other components can supply sharp, precise, bipolar clamp levels with continuous variable control, from 0 to В±11V. A feedback loop enclosing the amplifiers and zeners generates the high clamping accuracy.
  • Feedback Plots Define Op Amp AC Performance
    PDF, 89 Кб, Файл опубликован: 27 сен 2000
    Feedback plots simplify the analysis of an op amp's closed-loop AC performance by showing bandwidth and stability conditions as a function of the op amp's gain and phase response. These plots also provide insight into noise performance and the special feedback requirements of circuits such as integrating converters, photodiode amplifiers, composite amplifiers and active feedback circuits.
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
Серия: OPA111 (4)
На английском языке: Datasheet Texas Instruments OPA111SM
