Datasheet Texas Instruments OPA124P — Даташит
СерияOPA124
МодельOPA124P
Малошумящий прецизионный операционный усилитель Difet 8-PDIP
Low Noise Precision Difet® Operational Amplifier datasheet
PDF, 287 Кб, Файл опубликован: 27 сен 2000
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementOPA124U
Replacement CodeF
Additional FeaturesVos Adj Pin
Approx. Price (US$)4.15 | 1ku
АрхитектураFET
CMRR(Min)(dB)86
CMRR(Typ)(dB)100
GBW(Typ)(MHz)1
Input Bias Current(Max)(pA)1
Iq per channel(Max)(mA)3.5
Iq per channel(Typ)(mA)2.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)1
Operating Temperature Range(C)-25 to 85
Output Current(Typ)(mA)40
Rail-to-RailOut
Slew Rate(Typ)(V/us)1.6
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at 1kHz(Typ)(nV/rtHz)8
Vos (Offset Voltage @ 25C)(Max)(mV)0.25
RoHSНе совместим
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Comparison of Noise Performance of FET Transimpedence Amp/Switched Integrator
    PDF, 66 Кб, Файл опубликован: 27 сен 2000
    Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA124P
