Datasheet Texas Instruments TPIC6C596DR — Даташит
СерияTPIC6C596
МодельTPIC6C596DR
Автомобильный 8-битный сдвиговый регистр 16-SOIC -40 до 125
TPIC6C596 Power Logic 8-Bit Shift Register datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 15 сен 2014
Pin16
Package TypeD
Package QTY2500
МаркировкаTPIC6C596
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
EAS30 mJ
ICC20 uA
IO(CONT)0.1 A
IO(PEAK)0.25 A
VDS(Max)33 В
rDS(on)7 Ohms
tPLH80 нс
  • Power+ Logic Shift Register Application
    PDF, 91 Кб, Файл опубликован: 22 июн 2000
    The TPIC6C596 is a serial-in parallel-out, Power+ Logic 8-bit shift register with low-side switch DMOS outputs rating of 100 mA per channel. The device is designed to drive resistive and inductive laods and is particularly well suited as an interface between a microcontroller and LEDs or lamps. The TPIC6C596 is an enhancement of the TPIC6C595, where the shift register serial output (SER OUT)
  • TPIC6C596 Input Interface Routing
    PDF, 68 Кб, Файл опубликован: 20 апр 2011
    The TPIC6C596 can be used to switch a variety of low-side loads. Some loads induce transients that can be coupled onto components and traces that can feed back into the control circuits of the TPIC6C596. While the device is designed to minimize interference from external noise, the user should plan the board layout and external component placement to help reduce interference in very noisy applicat
  • Semiconductors > Logic > Power Logic
На английском языке: Datasheet Texas Instruments TPIC6C596DR
