Datasheet Texas Instruments OPA2111KP — Даташит
Серия | OPA2111 |
Модель | OPA2111KP |
Двойной малошумящий операционный усилитель Difet® 8-PDIP от -40 до 85
Dual Low-Noise Difet® Operational Amplifier datasheet
PDF, 193 Кб, Файл опубликован: 27 сен 2000
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | OPA2111KP |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 82 дБ |
CMRR(Typ) | 110 дБ |
GBW(Typ) | 2 МГц |
Input Bias Current(Max) | 4 pA |
Iq per channel(Max) | 3.5 мА |
Iq per channel(Typ) | 2.5 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.5 uV/C |
Рабочий диапазон температур | от -40 до 85,-55 до 125 C |
Output Current(Typ) | 40 мА |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rail-to-Rail | Out |
Rating | Catalog |
Slew Rate(Typ) | 2 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 10 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 7 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.5 мВ |
- Feedback Plots Define Op Amp AC PerformancePDF, 89 Кб, Файл опубликован: 27 сен 2000
Feedback plots simplify the analysis of an op amp's closed-loop AC performance by showing bandwidth and stability conditions as a function of the op amp's gain and phase response. These plots also provide insight into noise performance and the special feedback requirements of circuits such as integrating converters, photodiode amplifiers, composite amplifiers and active feedback circuits. - Comparison of Noise Performance of FET Transimpedence Amp/Switched IntegratorPDF, 66 Кб, Файл опубликован: 27 сен 2000
Low-input current FET operational amplifiers are universlly used to monitor photodetector, or more commonly photodiode currents. These photodetectors bridge the gap between a physical event, light, and electronics. There are a variey of amplifier configurations to select from and the choice is based on noise, bandwidth, offset, and linearity. A considerable amount has been written on the performan - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2111 (5)
- OPA2111AM OPA2111BM OPA2111KM OPA2111KP OPA2111KPG4
