Datasheet Texas Instruments TPL9201PWPG4 — Даташит
| Серия | TPL9201 |
| Модель | TPL9201PWPG4 |
8-канальный релейный драйвер со встроенным 5 В LDO и обнаружением нулевого напряжения 20-HTSSOP -40 до 125
8-Channel Relay Driver With Integrated 5-V LDO and Zero-Volt Detection datasheet
PDF, 687 Кб, Версия: D, Файл опубликован: 13 фев 2008
Купить TPL9201PWPG4 на РадиоЛоцман.Цены — от 29 до 86 ₽7 предложений от 7 поставщиков Драйвер FET, 8Channel elay Driver with Integrated 5V LDO and Zero-Volt Detection 20-HTSSOP -40℃ to 125℃ | |||
| TPL9201PWPG4 Texas Instruments | 76 ₽ | ||
| TPL9201PWPG4 | по запросу | ||
| TPL9201PWPG4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | PWP |
| Industry STD Term | HTSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 70 |
| Carrier | TUBE |
| Маркировка | PL201 |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Delay Time(Typ) | 10,80 нс |
| Drivers Per Package | 8 |
| Input Compatibility | CMOS |
| Iout/ch(Max) | 150 мА |
| Iout_off(Typ) | 2 uA |
| Output Voltage(Max) | 16.5 В |
| Package Group | HTSSOP |
| Package Size: mm2:W x L | 20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG |
| Peak Output Current | 150 мА |
| Rating | Catalog |
| Switching Voltage(Max) | N/A В |
| Vol@Lowest Spec Current(Typ) | 400 мВ |
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: TPL9201 (4)
- TPL9201PWP TPL9201PWPG4 TPL9201PWPR TPL9201PWPRG4
- Semiconductors > Power Management > Peripheral Driver and Actuator
