Datasheet Texas Instruments TPL9202PWPG4 — Даташит
Серия | TPL9202 |
Модель | TPL9202PWPG4 |
8-канальный релейный драйвер со встроенным 5 В LDO и обнаружением пониженного напряжения 20-HTSSOP -40 до 125
8-Channel Relay Driver With Integrated 5-V LDO and Brown-Out Detection datasheet
PDF, 689 Кб, Версия: D, Файл опубликован: 13 фев 2008
Pin | 20 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 70 |
Carrier | TUBE |
Маркировка | PL202 |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Delay Time(Typ) | 10,80 нс |
Drivers Per Package | 8 |
Input Compatibility | CMOS |
Iout/ch(Max) | 150 мА |
Iout_off(Typ) | 2 uA |
Output Voltage(Max) | 16.5 В |
Package Group | HTSSOP |
Package Size: mm2:W x L | 20HTSSOP: 42 mm2: 6.4 x 6.5(HTSSOP) PKG |
Peak Output Current | 150 мА |
Rating | Catalog |
Switching Voltage(Max) | N/A В |
Vol@Lowest Spec Current(Typ) | 400 мВ |
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: TPL9202 (4)
- TPL9202PWP TPL9202PWPG4 TPL9202PWPR TPL9202PWPRG4
- Semiconductors > Power Management > Peripheral Driver and Actuator
