Datasheet Texas Instruments TPS2023D — Даташит
СерияTPS2023
МодельTPS2023D
1,65 А, 2,7–5,5 В, одиночный переключатель распределения питания, ИС Hi-Side MOSFET, отчет об ошибках, включение Act-Low 8-SOIC от -40 до 85
TPS2020/21/22/23/24 - Power-Distribution Switches datasheet
PDF, 810 Кб, Версия: C, Файл опубликован: 24 сен 2007
36 предложений от 20 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Коммутаторы распределения энергии
TPS2023D
75 ₽
TPS2023D
219 ₽
Контест
TPS2023D
TPS2023D
Package TypeD
Package QTY75
Маркировка2023
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Continuous Current(Max)1.5 A
Current Limit TopologyConstant-Current
EnableActive Low
Number of Switches1
USB Switch rDS(on)33 mOhms
Vin(Max)5.5 В
Vin(Min)2.7 В
  • Protecting Industrial Digital Control Outputs Using Intelligent MOSFETS
    PDF, 55 Кб, Файл опубликован: 26 окт 2000
    Digital outputs in industrial applications often must implement some type of protection measure. The integrity of the signal, transmitted over a distance of several meters, can suffer due to fault conditions like a short circuit or an overcurrent, either of which can damage the device driving the signal. To prevent electromagnetic compatibility problems, it may also be necessary to slow down the s
  • TPS202x/3x And TPS204x/5x USB Power Distribution
    PDF, 116 Кб, Файл опубликован: 16 окт 1998
    The USB specification, revision 1.1, defines the power distribution requirements for the self-powered hubs (including hosts), bus-powered hubs, and functions. This application report demonstrates how Texas Instruments power management products meet or exceed voltage regulation, voltage droop, and EMI requirements in the USB power distribution system.
  • Power Management Solutions for Infiniband (SM) I/O Modules
    PDF, 75 Кб, Файл опубликован: 20 окт 2000
    InfiniBand, a scalable, modular, channel-based, switched-fabric architecture, is defined for the connection of servers with servers and with storage and networking devices. Because appropriate power management is essential for quality implementations, this report presents straightforward solutions for both high-power and low-power applications as required by the InfiniBand specification.
  • Power Supply Sequencing Solutions for Dual Supply Voltage DSPs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 5 июл 2000
    This application report describes power-supply sequencing recommendations and techniques applicable to dual supply voltage DSPs in TI's TMS320C2000 TMS320C5000 and TMS320C6000 families. These techniques take advantage of the reset power good enable and soft-start features available on TI Power Management Products including low drop out regulators switching power supply controllers supply vol
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2023 (5)
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
На английском языке: Datasheet Texas Instruments TPS2023D
