Datasheet Texas Instruments TPS2051BDG4 — Даташит
СерияTPS2051B
МодельTPS2051BDG4
Одинарный, токоограниченный, распределительный выключатель питания 8-SOIC -40 до 85
TPS20xxB Current-Limited, Power-Distribution Switches datasheet
PDF, 2.0 Мб, Версия: M, Файл опубликован: 19 июн 2016
IC PWR SWITCH N-CHAN 1:1 8SOIC. Power Switch/Driver 1:1 N-Channel 500mA 8-SOIC. PMIC - Power Distribution Switches, Load Drivers
1709791
Phoenix Contact
473 ₽
Hi-Tech Circuit Group
TPS2051BDG4
LifeElectronics
TPS2051BDG4
TPS2051BDG4
Package TypeD
Package QTY75
Маркировка2051B
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Continuous Current(Max)0.5 A
Current Limit TopologyConstant-Current
EnableActive High
Number of Switches1
USB Switch rDS(on)70 mOhms
Vin(Max)5.5 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: TPS2051BEVM
    TPS2051B Evaluation Module
  • Development Kits: TMDSCNCD28379D
    F28379D controlCARD for C2000 Real time control development kits
  • Development Kits: TMDSDOCK28379D
    F28379D Delfino Experimenter Kit
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Recommended Power Solutions for the TMS320x2810/1/2 DSPs
    PDF, 28 Кб, Файл опубликован: 31 янв 2005
    This application report provides a table to assist users in selecting the best power solution for their specific TMS320281x application.
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
На английском языке: Datasheet Texas Instruments TPS2051BDG4
