Datasheet Texas Instruments TPS2051BDGNG4 — Даташит
СерияTPS2051B
МодельTPS2051BDGNG4
Одинарный, с ограничением тока, распределительный переключатель питания 8-MSOP-PowerPAD -40 до 85
TPS20xxB Current-Limited, Power-Distribution Switches datasheet
PDF, 2.0 Мб, Версия: M, Файл опубликован: 19 июн 2016
IC PWR SWITCH N-CHAN 1:1 8MSOP. Power Switch/Driver 1:1 N-Channel 500mA 8-MSOP-PowerPad. PMIC - Power Distribution Switches, Load Drivers
TPS2051BDGNG4
77 ₽
Рутоника
TPS2051BDGNG4
88 ₽
TPS2051BDGNG4
1 649 ₽
МосЧип
TPS2051BDGNG4
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
Маркировка2051B
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
Continuous Current(Max)0.5 A
Current Limit TopologyConstant-Current
EnableActive High
Number of Switches1
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
USB Switch rDS(on)70 mOhms
Vin(Max)5.5 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: TPS2051BEVM
    TPS2051B Evaluation Module
  • Development Kits: TMDSCNCD28379D
    F28379D controlCARD for C2000 Real time control development kits
  • Development Kits: TMDSDOCK28379D
    F28379D Delfino Experimenter Kit
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Recommended Power Solutions for the TMS320x2810/1/2 DSPs
    PDF, 28 Кб, Файл опубликован: 31 янв 2005
    This application report provides a table to assist users in selecting the best power solution for their specific TMS320281x application.
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
На английском языке: Datasheet Texas Instruments TPS2051BDGNG4
