Datasheet Texas Instruments TPS2052DG4 — Даташит
СерияTPS2052
МодельTPS2052DG4
0,7 А, 2,7–5,5 В, двойной (1 вход/2 выхода) MOSFET Hi-Side, отчет об ошибках, включение Act-High 8-SOIC -40–85
Power-Distribution Switch datasheet
PDF, 589 Кб, Версия: A, Файл опубликован: 15 окт 1998
Package TypeD
Package QTY75
Маркировка2052
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
  • TPS202x/3x And TPS204x/5x USB Power Distribution
    PDF, 116 Кб, Файл опубликован: 16 окт 1998
    The USB specification, revision 1.1, defines the power distribution requirements for the self-powered hubs (including hosts), bus-powered hubs, and functions. This application report demonstrates how Texas Instruments power management products meet or exceed voltage regulation, voltage droop, and EMI requirements in the USB power distribution system.
  • A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
    Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2052 (4)
  • Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
На английском языке: Datasheet Texas Instruments TPS2052DG4
