Datasheet Texas Instruments TPS2062DGNR — Даташит
Серия | TPS2062 |
Модель | TPS2062DGNR |
Двойные 1A токоограничительные, силовые распределительные переключатели 8-MSOP-PowerPAD -40 до 85
Current Limited, Power Distribution Switches datasheet
PDF, 1.6 Мб, Версия: I, Файл опубликован: 29 окт 2009
Pin | 8 |
Package Type | DGN |
Industry STD Term | HVSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2062 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Continuous Current(Max) | 1 A |
Current Limit Topology | Constant-Current |
Enable | Active Low |
Number of Switches | 2 |
Package Group | MSOP-PowerPAD |
Package Size: mm2:W x L | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG |
Rating | Catalog |
USB Switch rDS(on) | 70 mOhms |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
- Evaluation Modules & Boards: TPS2062EVM-293
TPS2062EVM Evaluation Module
- Doubling the Power with Ganged TPS2062/TPS2066PDF, 170 Кб, Файл опубликован: 4 авг 2004
The TPS2062/TPS2066 devices are dual-channel, 1-A, power-distribution switches that are intended for applications where heavy capacitive loads and short circuits are likely to be encountered. These devices incorporate 70-milliohm, N-channel MOSFET power switches for power-distribution systems that require multiple power switches in a single package. When output load exceeds current-limit threshold - A Power-Distribution Switch With Latched Over-Current Protection (Rev. A)PDF, 99 Кб, Версия: A, Файл опубликован: 3 июл 2007
Power-distribution switches, like the TPS203x, operate in retry mode in an overload, but some applications require the switch to latch off. The latch-off function can be implemented using the simple circuit described in this application report.
Серия: TPS2062 (8)
- Semiconductors > Power Management > USB Power and Charging Port Controllers > Fixed Current Limited Switch
